Question about Sharp AR-C160 Color Copier
Sharp AR-C160 my sharp splits the colors e.x. from the black extracts yellow etc at the end of the page is dis focused what to do?
    Problem Solver:
  • 6 Answers
Replace color extraction unit .
Posted on Apr 25, 2008
Error code L4-05 for Sharp AR-C160 Digital
main motor lock detection
shifter motor trouble
Nov 26, 2009 | Sharp AR-C160 Color Copier
On my Sharp ar-c160 copier, where is the fusing unit thermal breaker?
its on the motherboard i believe, I used to repair copiers as a tech in the late 1980's
Jul 11, 2009 | Sharp AR-C160 Color Copier
I'm looking for a service manual for a Sharp AR-C160 Color Copier & Setup instructions for the sorter/stapler. Yes, I've found them online several places for a price, but why should we pay for them?
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
AR-S160(Japan only )
AR-160(Except Japan )
MODEL AR-161(Except Japan )
Exteriors
Operation panel section
Side door unit
Optical unit
2nd,3rd mirror unit
Middle frame unit
Process unit
DV cartridge unit
Fusing unit
Main drive unit
Base plate unit 1
Base plate unit 2
Manual paper feeding multi unit
Delivery frame unit
TC case unit
250 sheets tray unit
Packing material & Accessories
MCU PWB
I have this one, but i can't send a file writ to me to goodgold@inbox.ru
May 13, 2009 | Sharp AR-C160 Color Copier
Sharp Printer/Copier AR-C160
This answer is a rip off of MEITECH's answer to a very similar machine with the same code. I worked on Sharps for a few years and what he sais about this makes sense.
Here's the link:
http://www.fixya.com/support/t1640062-sharp_arc_270_error_code_l4_04
I give him credit and I gave him a 3 square rating for the help. He and I could both use a little rating boost. Thanks.
Possible bind in one or more of the developer units. Replace as needed.Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is thesame motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 21, 2009 | Sharp AR-C160 Color Copier
F2-57 Sharp AR C160 color copier
This is a problem with the drum and you may need to replace it to fix this problem...
Feb 16, 2009 | Sharp AR-C160 Color Copier
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Toner collecting containr of transfer unit
Remove the toner bottle and look for a black sensor. Clean it. Clean out all the toner in the bottle and try copying on it.
Oct 01, 2008 | Sharp AR-C160 Color Copier
F2 usually means its a component failure that should be looked at by a technician. You could trying turning it off wait 30 seconds and turn it back on again to see if it goes away.
Jul 23, 2008 | Sharp AR-C160 Color Copier
Error code F2-45
Ihave Sharp AR-C160. WHAT DOES THIS H4-01 ERRO CODE MEAN? How do I clear it?
Jul 18, 2008 | Sharp AR-C160 Color Copier
Calling for toner. toner full.
toner is not going in the developer
Dec 13, 2006 | Sharp AR-C160 Color Copier
Sharp AR-C160 Color Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
