Question about ViewSonic P815 21" CRT Monitor
Hi all! Got a problem with my excellent Viewsonic P815 21" monitor's CRT-board. Need schemetic drawing of CRT-Driver board because of HW-problem: Random flickering of Y intensity combined with a light colorshift while picture size/geometry of sweeping system stays pretty constant. - Might be a DC-shift on one colour amp or s.th. alike. On times the failure does not show up, the picture is nice and clear as always was. - I therefore resisted to chance that older (1998) but nicely engineered (Panasonic?) system against one of the LCD-Flatscreens. If it flickers it drives you crazy within a few minutes withstanding the fault. I do have some electronic metering equipment and tools for repair, but no electronic or paperware docu of schematics nor component locators. Anybody who can help? - Thank you! Gerd
SOURCE: ViewSonic E70f 17" CRT pincushion changed itsself continously
how to unlock osd lock
Posted on May 23, 2008
bammbammfran
  • 159 Answers
SOURCE: Viewsonic VX724 LCD Monitor
Hi.
If it isn't capacitors, It is usually the transistors that feed the backlight output transformers.
I fix many VX units with these issues.
Posted on Sep 12, 2008
chinna_1977
  • 65 Answers
SOURCE: schematic diagram of crt and lcd monitor.
I want ur mail ID
I will Give U
Posted on Oct 11, 2008
  • 152 Answers
SOURCE: How do you remove the outer case on Viewsonic VG930M-3 LCD
kauffman014, As far as opening the monitor up you may want to visit YOUTUBE and search for lcd monitor repair/ disassembling monitor/ or something like that. I did see a 9-11 min video there that was fairly good on un-snapping the rear cover from the front bezel of what I think was a DELL unit. Also visit electronicrepairguide.com run by a jestine yong. don't pay any attention to his ad to purchase repair course in lcd/fpd servicing!! only look at the pic's of the insides of lcd monitors and the power supply boards/inverter boards. On gateway's, and dell monitors the pedestal must be unscrewed from the rear cover first. The pedestal is really screwed down to the steel FPD chassis that covers the circuit boards and provides a ridgid mounting surface for the unit as a whole. Work on a flat surface with screen facing down on a blanket or lots of newspaper to prevent maring of the FPD!
There should be some phillips screws that fasten the steel shield to the left/right sides of the FPD frame. Once you get down to looking at the Switch-Mode-Power-Supply (smps) board look for large filter capacitors (electrolytic polarized aluminum can) that have the tops of them bulging upward as compared to normal ones that are flat. You will also need to inspect the bottom (solder side) of the board where all the leads of the components from the top side are soldered. You are looking for very thin hairline 'thermal' and or 'vibration' circular FRACTURES around the leads of the larger and bulkier (heavy) components. Yeah...use a big magnifying glass or better yet a 10x or 20x inspection microscope. One last thing, I highly recomend taking digital pic's as you disassemble the unit so it can be put together again without leftover parts. hope this info helps you out. Get back to me if you find out anything. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Posted on Mar 28, 2009
  • 90 Answers
SOURCE: Black screen. Won't power up.
Check the voltage of power in.
Posted on Apr 18, 2009
Display in black with one line in 1/4 of the top
Hi.
Please try to connect other monitor to your CPU.because I know the problem is in your video card graphic.also change your screen resolution to 1024 by 768.
if same problem again. need to check-up your viewsonic p75f+ crt monitor. some parts of your vertical video section capacitor leakages.
Jun 13, 2011 | ViewSonic P75f+ (Beige) 17" CRT Monitor
I have viewsonic monitor In my monitor the OSD lock screen is appear as like pop up many times\ its bored me very much how i can remove that?
you have a problem with the buttons. if you know how to open it try removing the buttons (plastic buttons). if still the same you need a technician to repair the board of your monitor. switches are needs to be replace.
Apr 12, 2011 | ViewSonic E70f 17" CRT Monitor
Download driver Viewsonic P75f CRT
With monitors you generally don't need drivers...especially for a CRT monitor. You can also use Windows Update and that will install any moniter drivers you might "need".
Feb 28, 2011 | Computers & Internet
Hi what is the model number for an e70fb backlight? i need to replace
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Sep 06, 2010 | ViewSonic E70fb 17" CRT Monitor
Unplugged monitor at one location and moved to a different location and the monitor will not work..... Tried a different monitor into the same PC and it worked fine. Viewsonic continues to go into power...
Sounds to me that it's a resolution problem. I think that the previous monitor that was hooked up to it last had a different resolution.
That or try restarting, it may need to install a driver.
Jul 10, 2009 | ViewSonic G810 21" SuperClear CRT Monitor
Screen goes blank
abandoned problem for now. will look for inverter board or parts from another monitor
May 12, 2009 | ViewSonic 22" FLAT SCREEN CRT BLACK...
How to open the back cover of Samsung SyncMaster 794mg CRT .
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Apr 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
VGA Problem
when u start sys press F8 KEY then go to safe mode and change resolution settings to 1024x768 or more
thern restart .
Mar 31, 2008 | ViewSonic VA1912w 19" LCD Monitor
Viewsonic VG919S 19" LCD
Hi
You must focus to mainboard of LCD monitor find the voltage regulator IC. Voltage test the regulator IC use digital or analog multimeter range 10v dc connect the negative to cold ground, these regulator providing a constant supply of 2.5 - 5v to all IC in the mainboard. check the scalar IC. Because scalar IC will convert analog input signal of Red, Green & Blue. Lastly check the controller board, check the ribbon cable connector from mainboard to
controller board for lose, check the fuse inside controller. I think the exact problem of your monitor could be either the (mainboard) or (LCD panel where the controller board is located).
Oct 06, 2007 | ViewSonic VG910S (Black, Silver) 19" LCD...
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
ViewSonic P815 21" CRT Monitor Logo
48 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
