2 Eth Cards one for Internet & one for LAN
I have 2 PCs named PC1 & PC2. PC1 have 2 Eth cards. PC2 have 1Eth card. I have a broadband modem with one network port and one USB potr on it.I also have a HUB.I want to configure the network as follows,
In PC1
Eth0 - connected to internet (Modem)
Eth1 - connected to LAN (HUB)
In PC2
Eth0 - connected to LAN (HUB)
I want both PCs can access the internet.
Give me the compleate details of what should be the IP adresses,Subnet Masks,Default Gateways of all the Eth cards.
    Scholar:
  • 60 Answers
First of all, I would really recommend you to buy a Cable/DSL router. It is quite cheap, usualy more secure, much easier to configure and troubleshoot. Also, it does not require to have one PC up and running all the time, hense saving energy. Do you know that a PC running 24/7 may cost between 60$ and 100$ in electricity annually? This is more than the cost of a basic router!
But, since your question is about sharing your Internet connection with a PC, here are some guidelines. I will assume here that you are using Windows XP.
On PC1:
1. Connect the modem to Eth0 in the PC. Do not connect anything in the USB port of the modem.
2. Make sure that the link lights are lit both side. If they are not, you may need a cross-over cable (this is usualy not the case)
3. Configure Eth0 to get IP address DNS automatically
4. Disable (uncheck) all protocols except TCP/IP on Eth0.
5. Run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps.
On PC2:
Simply run the Network Setup Wizard (Start > All Programs > Accessories > Communications > Network Setup Wizard) and follow the steps. Specify and you Internet connection is through a Home or LAN network.
That should do it.
Posted on Apr 27, 2008
What is difference between lan card and modem
The difference between a Lsn Card and a modem are this - A Lan card is a card that you slide into the side of a laptop and it can allow you the ability to get onto a network wirelessly. A Lan card for a PC allows a Lan connection by way of a CAT 5 cable that will allow you to get onto the internet or if a crossover cable is attached to your pc to another you are directly connected to the network. A modem is a piece of hardware that is installed into a slot in the PC that will allow you the ability to get onto the internet by attaching a phone line to it through the RJ 11 jack (which it comes with 2 rj11 jacks on it).
Here is the picture of LAN port and Modem port
Dec 24, 2010 | Siemens Computers & Internet
How to first time d link connection and broadband for 2 PC. setup information pl.
Here is what you need to do.
1. Prepare the modem provided to you by your internet service provider. If you are wired broadband subsidiary......connect the phone line to the modem (if a splitter is attached make sure that modem labeled out is connected to the modem line input).
2. Now connect modem and d-link. Using a lan cable from the modem connect it to wan port of the d-link.
3. Connect the two pc's using another lan cable from the lan card at the back of your pc to the lan ports of the d-link.
That's the setup.
Try to turn all devices and the pcs and see if that connects.
If you are planning on accessing the ip configuration of the dlink, type in the address bar of your internet browser 192.168.0.1... default username is "user" leave password blank.
Should you have anymore queries, just post back.
Thanks
Mace
Dec 12, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
I have 10 computer.i want to connect it to the
u have to connect all the PCs to the HUB first...then connect the Hub to the Router(broadband modem)...u need to first establish a connection to the internet serivce provider by entering the necessary IP address/subnet mask/gateway address etc in each PC...
Note each PC will have a different IP address
PC1 - 192.168.1.5
PC2 - 192.168.1.8 etc etc...not necessarly in the order mentioned above....
the rest of the settings will remain the same in all PCs
refer attached word doc
reg
pls let me know if this was helpful...leave a feedback...
Jun 16, 2010 | Linksys WRT120N Router
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Nov 26, 2008 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
PPPoE over Edimax BR-6104K without a modem
I am not sure if I understand you well.
You say:
My Internet is a PPPoE broadband connection but I don't have a modem installed.
What do you mean ?
You have a Broadband/ADSL modem, but you didn't install any software for it ?
(It is probably not necessary.)
So, I assume you do have a modem. You connect your modem to the wall outlet with a telephone cable.
Then then modem is connected with LAN cable to one of your PC with two NICs, you make Internet Connection Sharing, and ten from the second NIC of that PC, you connect (again) with LAN cable, your second PC.
If it is an ADSL or Cable modem connected with LAN cable, please follow this steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect your PC (the one with one NIC) to one of the 4 LAN ports of your Router wit a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres: 192.168.2.100
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.2.1
Open your browser and type http://192.168.2.1
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
PPPoE.
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APLY, and again APLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable. (***)
Now:
if you've typed your User Name and Password correctly in PPPoE fields,
and
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the PC with two NICs.
Go to Control Pannel, and go to Network Connections.
Right-click on one of your NICs and click 'Disable'.
Check the other NIC if 'Internet Protocol (TCP/IP)' settings are set to Obtain IP addres and DNS - Automatically, and 'Show icon notification when connected' and once again click OK.
Connect the (enabled) NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
If you (somehow) realy don't have a modem, but you have a cable only, follow the above instructions to the point (***) and connect the cable to the WAN port of your router.
That's it!
Regards
Aug 28, 2008 | Edimax BR-6104K Router (br6104k)
Ef3116 has different up and down speed.
PC1 may have a defective NIC card. Also, verify that PC1's NIC card is using an up-to-date driver and that it's interface speed and duplex settings are set to auto-negotiate.
Jan 09, 2008 | Linksys EtherFast 3116 Port 10/100...
BSNL Broadband connection
In brief yes. 2 possible ways:
1. Use a router; or
2. Configure 1 of your PCs to be the Default Gateway and enable Internet Connection Sharing (this is where the single user broadband connection must be plug in). If your modem uses USB connection to the PC (Gateway), use the LAN card IP add as the Default Gateway of the other PCs in your network. If your modem uses the Ethernet port, you need to install a 2nd LAN card on the same PC and do the same configuration.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Computers & Internet
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Home networking
You need to go to control panel>network set up wizard on the pc which has the internet connection and when you go through the wizard amongst prompts select, allow other computers to connect through this computer and then finish off the wizard. On the other computer you do the same but, on this one select this computer connects via another computer on the network and again finish off the wizard.
Oct 02, 2007 | Acer ALW 3016 Networking Switch
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
