Question about Canon MV920 Mini DV Digital Camcorder
How can i capture my recording from the Canon MV920 Mini DV to the computer?
I have a Canon MV920 Mini DV cam corder with last three months but still i don't know how can i capture my recording from the Canon MV920 Mini DV to the computer?
And i want to also know that which instrument/cabel/softwere have i need to capture my recording to the computer.
I want to make CD of my recording how can i do that?
pls, help me.
pls send me solution on my E-mail ID as below:
ronakkunjadiya@yahoo.com
or
rv_kunjadiya@yahoo.co.in
Your's faithfully.
Ronak V. Kunjadiya
0909020555
  • dsynart Jul 03, 2008
    Cannot transfer Canon MV920 recording to my computer.
  • tushsen Nov 24, 2008
    Hi, I have a Canon MV920 and have tried all the possible cables and software to transfer my videos to my hard drive with no luck.
    If anyone has any idea of how to resolve this, would you please email me at i@tusharsen.net
    thanks,
    tushar
After you put the cable IE1394 into the card IE 1394 your computer or laptop you can use moviemaker in microsoft with capture or edit on the moviemaker you can import and capture form camera
ron thailand 0831819970 sawadichais@yahoo.com
Posted on Jan 16, 2009
Computer is not recognising camcoder cannon mv920
Depending on the type of connection that you have between the camera and the computer, you may have to reload either the camera software or update the computer USB or IEEE1394 drivers. I would first check the cable to make sure it is not the problem.
Sep 28, 2013 | Canon MV920 Mini DV Digital Camcorder
Hello can you please tell me how to copy video recorded in tape using canon mv920 into my laptop. Is there any driver available for that if so please could you give me the information Thanks in...
-turn on and switch your camcorder to playback mode and make sure that the tape is totally rewounded.(you're going to stream the video from the cam to pc using a supplied software or a thirdparty software like windows movie maker)
-connect your camcorder to your pc and you have to use a dv cable(4 pin to 4 pin or 4 pin to 6 pin type) the first end is a 4 pin which will be connected to your camcorder and the other end depends on what type of dv port you have in your computer(4 pin or 6 pin) Use the optional CV-150F (4 pin-4 pin) or CV-250F (4 pin-6 pin) DV Cable. the dv port on your camcorder is on the strap side on the upper part and its covered by a oval rubber
-once connected to the computer,ready your software(supplied or any other software that could record streamed videos ie: windows movie maker.
-play video from the camcorder then hit the record button from software( you're basically recording the videos from the camcorder live to your pc :)
- reply or post for questions
Jun 05, 2011 | Canon MV920 Mini DV Digital Camcorder
My computer can't read the canon as removable device? I can't download my recoding.
Connect your cam to another computer to confirm If so your PC is having errors in the software or that the port is defective. If not the software must be removed and reinstalled.
May 09, 2011 | Canon MV920 Mini DV Digital Camcorder
I have an acer 5740G laptop to which when i am connecting the MV 920 cannon cam corder through the camera's port in to the laptop's USB port, the laptop does not recognise this as an external removable...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. With desktop Windows PCs, you can fit an add-on Firewire interface card. This comes with a driver for the card. If your laptop doesn't have a Firewire socket, then you are probably stuck.
Nov 07, 2010 | Canon MV920 Mini DV Digital Camcorder
Can i use external boom mic for my canon mv920 mini dv camcorder? will the socket match with my camcorder's?
If your cam has an external mic jack and your mic has the matching connection you should be golden if they don't have the same connection try radioshack they should be able to hook you up with an adapter...If their adapter is insanely priced try monoprice.com.
Oct 26, 2009 | Canon MV920 Mini DV Digital Camcorder
Cannot see anything through the viewing lens
I have same prob, check this out:
http://support-sg.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
Kiri
Jan 30, 2009 | Canon MV630i Mini DV Digital Camcorder
Transfer video recordings to computer.
after you put the cable plug IE1394 into the card IE 1394 your computer or laptop you can use movie maker on microsoft with capture or edit on the movie maker you can import and capture form camera for USB you must have movie box ( pinnacal ) change IE 1394 to USB57b383f.png
Jan 08, 2009 | Canon MV920 Mini DV Digital Camcorder
I need driver for canon mv920 digital camcorder pal
Here is download page, click and follow instructions.
Run the driver on the computer before connecting camcorder, after the download has finished.
Dec 15, 2008 | Canon MV920 Mini DV Digital Camcorder
Canon MV920 Mini DV Digital Camcorder Logo
471 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
