Question about Sport & Outdoor - Others
My Nordic track C2270 treadmill no longer has power when plugged into the wall and key is inserted. Need help with what could possibly be wrong with the treadmill. It was working great 1 week ago. Thanks in advance
  • brettkozel Aug 04, 2010
    Thanks alot.
  • 677 Answers
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Good luck.
Posted on Aug 02, 2010
I have a Nordic Track C2155 that doesn't power up on the display after inserting key. The red LED on the power supply board does light up
The circuit board is fried. It's too expensive to have fixed if the warranty is expired. You can try and find a used display from ebay or craigslist. It would be an easy swap.
Jan 01, 2017 | Nordic Track Exercise & Fitness
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
My treadmill is telling me the wrong amount of calories burned and the wrong speed at which I am traveling. For example, I hit the button that says 6 mph, but the treadmill says I am running at 9.7 mph....
I had the same problem with my Nordic Track. I had somehow changed the display to metric readings.
Solution: Hold the stop button down while inserting the key, push the speed up or down button to change it back to english, remove key and you are good to go. Re insert the key and it should work fine. Hope this helps.
Nov 27, 2010 | Nordic Track Nordictrack Adventurer...
How do I turn it on? A2350
Make sure the power is plugged in then insert the red safety key into the front. If you are not receiveing power after that then check that it is a dedicated outlet, that is not a gfci outlet, and that the breaker is not flipped.
Aug 06, 2010 | Nordic Track NordicTrack A2350 Pro...
Display turns on, manual mode, but beeps (4 times) every time I touch a button, it will not start up to run correctly
Press the Stop and the Speed Up keys down while inserting the safety key this should get you in to calibration mode. If not then you possibly have a keypad/upper electronics failure and depending on cost will need replacement.
May 31, 2010 | Nordic Track NordicTrack Treadmill, A2550
My Nordic Track EXP 1000 won't run.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413
Part Name: ASSY,CLIP,ROPE/KEY
Model: 248110 - NORDICTRACK ELITE ZI TREADMILL
Part List: #264413 - KEY/CLIP
Quantity on Model: 1
Price: $9.82
May 17, 2010 | Nordic Track NordicTrack Elite zi...
How do you adjust or tighten the belt on the Nordic Track A2750 The belt is riding to one side of the platform
If the walking belt is off-center, remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left idler roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 14, 2010 | Nordic Track NordicTrack A2750 PRO...
Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Jan 12, 2010 | Exercise & Fitness
Sport & Outdoor - Others Logo
179 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
