My hoover washing machine overfill - Washing Machines
  • alfredo_land Aug 02, 2010
    alredy tried the valve & is allrght
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the washer is overfilling it’s caused because of water-inlet valve going bad. It's the device with the main water line from the house and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 02, 2010
    aredy tried the valve
A video shows Phrophore changing carbon bushes on a hoover washing machine. Please could he let me know were he got them from as I require a pair. Thankyou for your help in this matter.
Hello, D_curry751 -
It will help in directing to the best source for you for purchasing carbon brushes for your Hoover washing machine, if you indicate the country where you reside. You can add that information in the Comment box.
Note: Questions come into Fixya.com from all over the world and it can be hard to guess what the best resource for the right information.
Without knowing the country of your residence, I did find Hoover washing machine carbon brushes sold online (USA web sites):
eBay:
https://www.ebay.com/b/Hoover-Washer-Dryer-Carbon-Brushes/99697/bn_5864242
Amazon:
https://www.amazon.com/Genuine-Washing-Machine-Brushes-09036062/dp/B00EO4QZAW
These are United Kingdom websites selling Hoover washing machine carbon brushes:
eBay, United Kingdom:
https://www.ebay.co.uk/b/Hoover-Washing-Machine-Dryer-Carbon-Brushes/99697/bn_3272613
BuySpares, United Kingdom:
https://www.buyspares.co.uk/washing-machine/hoover/carbon-brush/catalogue.pl?path=495970:496360,45786:495976&refine=carbon+brush
PartMaster, United Kingdom:
https://www.partmaster.co.uk/hoover/washing-machine/carbon-brush/catalogue.pl?shop=hoover&path=45786&refine=carbon%20brush
Jan 09, 2018 | Hoover Washing Machines
Hoover elite washing machine
FIXYA has no idea of any parts for hoover machine . contact hoover direct
Oct 23, 2017 | Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover 705 , overfills and fllods laundry can it be fixed
On my hoover 200m (top loader) I had a similar problem. I turned off the machine & unplugged it. Closed water taps both hot & cold. Manually emptied machine with large cup. Undid bottom outlet hose by unclipping.The residual water will come out! I undid the 3 screws on the control panel. Tilted the control panel forward. The water level is manual control using a diagaphram pressure control to set water level. This had a hose. I disconnected both ends and used a bicycle pump to blow air thorough it. Underneath I disconnected where the hose goes into machine (clips) and also blew air from the top to check it was clear. After reconnecting everything the machine now does not stop filling and does not overflow anymore. Hope this helps.
Jul 28, 2012 | Hoover HTC243 Top Load Washer
Hoover Interact 1600
This might sound silly, but try it. Run the washing machine through an entire cycle with nothing in it. Select the largest and longest cycle you can. Once this is done, is that error code still there? In some cases, this will clear it. This can be due to overfilling the soap and thereby triggering the sensors that are there to monitor pressure. Running it with no soap or clothes in it may clean this excess out of the machine. Another solution may be a faulty inlet valve allowing too much water into the tub to begin with...let me know what happens
Jul 01, 2012 | Hoover Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Apr 30, 2008 | Hoover HTC243 Top Load Washer
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
in case your thirsty!no I'am jokeing of course it works the water level switch if it blocks the machine would overfill,top of the morning to you Eire
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
