Question about HP PSC 1350 All-In-One Thermal Printer
What does this mean?? The carriage is stalled.
  • 69 Answers
Try cleaning or cancelling all print jobs and resart your printer after unpluging all the cables and even tryto uninstall and then reinstall all the drivers and firmwares for this printer.........goodluck!
Posted on Aug 02, 2010
Pump motor stalls in my HP printer
When an inkjet printer is making "awful noises" it means that there is either a paper jam or the carriage can't move properly. Remove all paper and check for a paper jam - if this is not the problem, turn off the printer and see if you can move the print cartridge carrier by hand. If it is hard to move, clean the shiny carriage rod with a cloth and put just a drop of light oil on it. Move the carriage back and forth and clean it again - repeat until it moves easily and add a final drop of oil to the rod.
Oct 14, 2014 | HP Photosmart C7280 All-in-One Printer
HP Officejet Pro K8600 CARRIAGE STALLED
Make sure that you have tried the steps in the following web link:
https://support.hp.com/in-en/document/c01287261
If the issue persists, then this is a hardware issue. From my experience Carriage Stalled errors are usually due to a hardware failure.
Regards,
Dr. Tony
Mar 04, 2017 | HP OfficeJet Pro K8600 Printer
I received a new printer today, I installed the software and ready to test print page. I get error message that the carriage is stalled. I found a procedure on HP web site that to fix problem, but it...
The printer may be faulty. I suggest you return it to the supplier to have it fixed or replaced under warranty. If you try to fix it yourself you may void your warranty.
Jul 14, 2011 | HP H470 InkJet Photo Printer
My HP C5280 Printer has an error message "carriage stall". None of the suggestions made on the website have worked. Seems to be in a continuous loop. How can I get a hardware reset or local...
A carriage stall either means the carriage cannot move, or the printer THINKS the carriage isn't moving.
Most HP printers use a calibration strip to tell where the carriage is, and if that breaks, there's nothing you can do about the carriage stall message, the unit has to be serviced or replaced!
Here's a quick test though.disconnect the power from the unit. Reconnect the power, and while the whirring and so forth is going on, disconnect the power again.
See if you can move the carriage (the part with the printheads) all the way left, and all the way right.
if it sticks, find out what's obstructing it, because that's the problem.
If you CAN move it all the way left and right, chances are that calibration strip is broken.
Mar 19, 2011 | HP Office Equipment & Supplies
Hp business ink jet 2800 printer carriage stall clear carriage obstruction press resume to continue
i get this message on my printer
carriage stall clear carriage obstraction
i change the prints head and the colours catrage and still have the same message
can u help me
Jun 30, 2010 | Office Equipment & Supplies
It is telling me cartridge error What does that mean
Did you just replace a cartridge. Sounds like you used the wrong one.
Oct 01, 2009 | HP Officejet 4215v All-in-One Printer
Message says carriage is stalled
Please Click Here and follow the instructions on the document to resolve this issue.
May 26, 2009 | HP DeskJet F380 All-In-One Printer
HP CM8060 Error code C1.132A
2 possible causes for this are Carriage stall and paper on drum at SN57 Carriage 2 Pen Protection sensor. Some MFP's can experience intermittent motor stalls due to maladjusted upper right front door latch when minor movements cause the door actuator to open the door switch . this can then show up as a carriage stalled. also check for carriage 2 binding and that the aerosol hose and snorkel are seated properly.Check the plastic sensor actuator for damage and contamination. last chance could be Pen Pocket 4 PCA (A19).
Apr 18, 2009 | HP Office Equipment & Supplies
Resubmittance stall problem
try lubricating the carriage with WD40, put on a towel and rub the carriage, it may be too dry and can't move easily. " carriage stalled " means it started to move but for some reason it stopped.
Feb 12, 2007 | HP DeskJet 3930 InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
158 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
