Question about Maytag 24 in. MDBH950AWS Built-in Dishwasher
Heating element stays on after cycle has completed. Goes off when door is open. Maytag MODEL MDB5601.
  • Maytag Master
  • 17,130 Answers
It is possible that the relay is actuated from the control board and gets disconnected only when the safety swtich is engaged- when you open the door. hence you will need to check into the circuit to trace, from the heater to the driver relay. Checck if there is a short or a false trigger. This may be a bit difficult as the PCB- printed circuit board - may be filled with epoxy to prevent moisture build up and testing could be difficult. Normally the companies recommend board change but you need to check if familiar or get help to probe into this switch on. Hope you try this out. Good day
Posted on Aug 02, 2010
Testimonial: "Thanks for the advice. I read other online fixes such as disconnecting power supply & running fresh cycle to reset board - will try those too."
When door is open during drying cycle, dryer continues to heat up.
no,it sounds like the heating element is touching metal and as long as the timer is sending power until it goes to off it will keep heating.change out the element
May 21, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
I have a maytag mdb5130 that the soap is caking in the dispenser so not going out and cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 17, 2011 | Maytag Dishwasher
The heating element stays on if the door is opened,goes off if timer knob is pushed in,but well go of after the cycle has finished
does the dryer still run when you open the door?if so check the door switch,push it in and out a few times to see if the dryer will shut down,sounds like a bad door switch
Apr 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Heating element stays on when dryer is off.
I would advise to inspect the high limit thermostat. this device may be defective. this will cause the element to continue to operate when the unit is off as well. If the thermostat is operating correctly, replace the timer.
Aug 12, 2009 | Maytag PYE2300AY Electric Dryer
Heating element
if it does not stay red after you open the door then it's ok. but opening the door in mid cycle is not a good habit. turn off heat for a minute first will help the elements last longer.
Jun 12, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Heating element won't stay hot.
Hello vsjant3,
I assume you cheated out the door interlock switch when running your test. If you did not, then the dryer will shut off when the door is open as part of the safety interlock system. If you did cheat it out and the element shut off after about 20 seconds, then you may have a problem with one of the temp sensors. When an overtemp condition occurrs, it disables power to the heater and it will shut off.. Other considerations are the wiring to the heater.. if you had a poorly tightened heater wire that was ok when first started and cold but when hot and passing current opened, that would also exibit the same symptoms. If I were a betting man, I'd say you probably have a bad temp switch. You can measure them with an ohm meter ( dryer unplugged of course).. or simply jumper the wires together to bypass one to see if it is the fault. Make sure you replace a bad sensor and do not leave it bypassed or you risk fire.
Here is a link to the wiring diaghram of your dryer.. http://www.pcappliancerepair.com/model-display.php
Hope that helps,,
Regards,
Rick
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Soap dispensor door opens, but powder soap mostly stays in the cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 15, 2008 | Maytag PDB3600A Built-in Dishwasher
Vulcan dishlex 750 eco taking alot longer to complete wash cycle.
How is the water flow into the machine. Are all your inline filters clean?
Apr 05, 2017 | Dishwashers
Maytag 24 in. MDBH950AWS Built-in Dishwasher Logo
211 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
