Question about Canon PIXMA MX310 All-In-One Printer
My Canon MX310 Pixma won't prinfaxes from memory I have refilled black Cartridge
  • wowk Aug 09, 2010
    Your solution is not the answer, faxes can be printed manually from Menu selection, but automatically from memoray will not print.
    Thanks Alex wowk
  • Canon Master
  • 4,737 Answers
Do you have another black cartridge? If so please install it and try again. Clean the cartridge's print head and contact points. Also clean the contact points on the printer. You can use cotton {or soft sponge} dipped in alcohol/acetone..or similar solution, wipe the head very gently and also clean the contact points with it. Leave it to dry for few minutes and again install it. Now try printing one of the saved faxes again.
I would also suggest you to use a new cartridge to make sure if the problem is related to Cartridge.
If above measures don't fix, you need to reset the printer which means you'll loose all the saved faxes on the Printer's Memory. Anyway, this is the final option, let's see after you are done with the above mentioned suggestions.
Contact points on the cartridges look like this:
and the one on the printer is the corresponding part on the printer where the cartridges are installed.
Good luck
Thanks for using FixYa.
Posted on Aug 09, 2010
    Genius:
  • 1,478 Answers
I suggest you check the cartridges very well, because it is possible that the cartridges you refilled are not properly filled well, Check to ensure the printer recognizes it.
Take care.
I whant to refill pixma canon ip2700 with black ink but dond now how
Color Cartridge 1. Place the cartridge over somepaper towels in case there are any spills.Remove the label sticker from the topof the color cartridge. 2. Drill into the three small holeson the top of the cartridge to widen them so they will allow syringe needles. 3. Fill a syringe with 6 mL ofmagenta ink. Insert the needle into the refill hole that is located below thetwo protruding rectangles on the top of the cartridge. Slowly inject the ink. 4. Fill a syringe with 6 mL of cyanink. Insert the needle into the refill hole located below the large rectangleon the top of the cartridge. Slowly inject the ink into the cartridge. 5. Fill a syringe with 6 mL of yellowink. Insert the needle into the refill hole located below the small rectangleon the top of the cartridge. Slowly inject the ink into the ink chamber. 6. Replace the cartridge into theMX310 printer. Black Cartridge 1. Set the cartridge on some paper towels. 2. Drill a hole into the dimplelocated directly above the semicircle on the top of the cartridge.Fill asyringe with 20 mL of black ink. Insert the needle into the hole and slowlyinject the ink. 3. Replace the cartridge into theCanon MX310.
Nov 28, 2010 | Canon PIXMA MX310 All-In-One Printer
WILL NOT PRINT FROM MEMORY
I cannot recieve a fax from memory, I have refilled B cartridge, Window display recomends new cartridge, I can make a copy in copy mode, this tells me cartridge is OK. my machine is a Canon
MX310
Jul 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Printer wont accept toner cartridge U150 error comes up canon MX310
do you use genuine canon replacement cartridge or OEM cartridge? if it is OEM or refilled one there is a problem however there is a trick to reset the cartridge chip,otherwise you cant use it.If it is an original canon it should not be a problem at all..Regards
Jan 08, 2010 | Canon PIXMA MX310 All-In-One Printer
Cannot receive fax. It goes into memory. LCD reccomends new B-CRT regarding my Canon PIXMA MX310 printer . No problem sending fax,copying or printing.
B-CRT is just asking for a new black cartridge, fax will not print until it's replaced so you don't get a partial fax that you can't get back after printing.
Nov 05, 2009 | Canon PIXMA MX310 All-In-One Printer
HAving trouble printing
Check and make sure you did buy the right one first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 - refilling cartridge
Most canons have a chip on the ink cartridge that tells the printer the ink is empty so unless you reset that chip (which you cannont do), that newly filled cartridge will always read empty. This is how some printer manufacturer's thwart people saving money by refilling their cartridges.
thanks and please take a moment to rate as fixya.
Sep 09, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon mx310
Canon cartridges have an intelligent chipset to prevent them from being refilled. To have them working properly you need to reset the chipset.
Try the software on this link.
If the above did not work you will need to use a cartridge chip resetter if you want to refill your cartridge.
Jun 06, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
23 people viewed this question
old marine
old marine
