Question about Gladiator GAFZ21XXMK Bottom Freezer Refrigerator
Our gladiator bottom freezer/refrigerator stopped working while we were on vacation last week. The motor still runs, but the air blowing out is not cold. We cleaned it out, unplugged it and plugged it in again, but no change.
  • Gladiator Master
  • 17,130 Answers
It is possible that your compressor has redduced in pumping or the gas pressure has redduced, ;leakage of gas. Sicne you had put off the fridge for sometime and tried again without any result, I think the compressor needs a good check. Since the fridge has to cool definately when the motor runs we must start from here . I hope you check this out or maybe get help to confirm definetely with an estimate. Good day.
Posted on Aug 02, 2010
Gladiator freezerator loud noise
Loud noises means that the Freezerator is working like it should be. The defrost heater element is on and the noise from melting ice dropping off the coil located in the back of the refrigerator section.
Jun 01, 2014 | Gladiator Freezerator Top Freezer...
Gladiator Freezerator wont stay frozen in the bottom portion. It will go to temp when temp is mved, but then start to warm up. Why?
If the bottom freezer section of the Gladiator Freezerator is thawing out the usual cause is from the coils in the back of the top refrigerator section being iced up. The ice blockage prevents the fan from circulating cold air into the bottom freezer section. These units have a design flaw due to the defrost drain freezing up preventing water from draining out from under the coil. The long-term solution is to remove the back wall of the refrigerator section to get to the coil, thoroughly defrost the coil making sure the drain tube is clear, then wrap a couple turns of #12 or #14 copper house wire around the bottom of the defrost heater element and run it a few inches into the drain tube. Advise unplugging the unit when you do this.
I've had this fix on my Gladiator for a couple years and it has been working perfectly ever since. The freezer stays a constant 0 degrees F and no more thawed out food.
May 09, 2014 | Gladiator Freezerator Top Freezer...
Freezerator leaking water into freezer that is freezing in bottom of freezer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Gladiator Freezerator Top Freezer...
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 12, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Ice buildup in freezerator freezer section
If it is not a frost less freezer you'll have to remove perishables to another fridge/freezer; unplug and de-thaw the unit.
Nov 21, 2009 | Gladiator GAFZ21XXMK Bottom Freezer...
The bottom freezer portion of my gladiator freezerator forms ice
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Nov 09, 2009 | Gladiator Freezerator Top Freezer...
Ice build up
You should to check the Whirlpool Gladiator Freezerator's door sealer to make sure all rubber or plastic seal very well to prevent air humidity come in to build up frost fast. Also, you have to defrost completely and wipe with cloth or paper towel to absorb all waters out and let it dry completely to prevent frost build up.
May 08, 2009 | Whirlpool Freezers
Bottom freezer not working
Hi, sorry I do not have any advice to offer. We have the same model. Three weeks ago the red light came on and freezer stopped working. Last week the fridge packed up. We may have been unlucky but I thought it might be worth mentioning incase they were related and your fridge gave up as well.
Jul 06, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Gladiator GAFZ21XXMK Bottom Freezer Refrigerator Logo
289 people viewed this question
Top Gladiator Refrigerators Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
