Question about Fujitsu 36CS Air Conditioner
Hi I have a fujitsu inverter model number AR-RY3. Could you please tell me what the Master control button does, should I set it on heat or cold. And could you please tell me what the fan control buton does and also what SWING button means. Regards Vince
3 Suggested Answers
notsomot
  • 67 Answers
SOURCE: my fujitsu inverter does not cool below 18deg C
Heya Mark,
Fujitsu air cons are factory set at 18degs you cannot change it without going through all the controller programs. Normally air cons are serpose to run around the 20deg point, is the air con not running effectually or do you just really like it cold.
I could check with tech help and see if I can send you the derictions of changing the minimum set point but it will not be good in the long run for your unit
Posted on Jan 08, 2009
  • 3 Answers
SOURCE: hOW DO I SET THE
Right above the 'CLOCK ADJUST' there is a small hole, you need to push a ballpoint pen or something into that hole, to allow you to set the clock using the - and + buttons next to it. Then press the pen into that hole again in order to finalize the time.
Posted on Apr 06, 2011
The heating is not working at all on my fujitsu air conditioner
Should have an heating element inside...that one I think is broken or can be also the thermostat..
Jul 12, 2013 | Dishwashers
HOW DO I SET THE TIME on Fujitsu AR-RY3
Dec 09, 2010 | Fujitsu 36CS Air Conditioner
How to change the time on my Model Number: AR-RY3 remote conrtol
Nov 15, 2010 | Fujitsu 36CS Air Conditioner
We just moved into a rental. It has the Fugitsu wall-mounted Air-conditioner model: ar-jw2 but, there was no manual left behind and we are trying to use the heat, however, it just blows cool air, we're not...
Look, if you select a temperature above ambient temperature, it will switch from cooling to heating.(assuming that the aircon has a heat pump. most do these days.) Just dont rush the aircon because every time you make a setting change, it takes a while to regulate.
Aug 12, 2010 | Heating & Cooling
Hi I have a Fujitsu Split system. As of recently it has started to mysteriously started to flick over from heating to cooling on its own. It is a 2.5KW unit and heats rather well. ALl of a sudden you hear...
Yes i can! The mode of operation (MASTER CONTROL)has been set to AUTO instead of HEAT. Easy mistake and very simple to fix. Press the MASTER CONTROL button until HEAT is display on the LCD.
I hope that this helps
I take the time to answer you questions so please rate me
Thankyou
Mat
Jul 13, 2009 | Fujitsu 18R1 Air Conditioner
My fujitsu inverter does not cool below 18deg C
Heya Mark,
Jan 07, 2009 | Fujitsu 36CS Air Conditioner
Fujitsu 36CS Air Conditioner Logo
443 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
