Question about Apple iPod nano
I pod is blocked, everything seemed to be normal and now its stuck on playlist nothing seems to work, screen is alight though
    Scholar:
  • 66 Answers
Your iPod needs to be reset. 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Aug 02, 2010
    Filmmaker:
    Uploaded 5 video answers.
  • 26 Answers
This video will explain the reset process! ">
Posted on Sep 30, 2010
My Nikon Coolpix S01 takes a very faded picture, which also shows on the screen. What caused this, and is it fixable?
All I can think of is either white balance, or exposure compensation. Have either of these deviated from the norm ?
Oct 06, 2016 | Nikon Inc Nikon Coolpix S01 Silver
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you...
I have a dolce gusto and i am unable to remove the coffee capsule. It seems stuck, as does the lever that punctures the capsule. If the valve lever is moved right or left nothing comes out. Please can you help?
Feb 23, 2010 | Krups Coffee Makers & Espresso Machines
Everything on my screen seems inflated, though I
Right click on a free space on your desktop and goto properties, the click on the tab that says settings and change the screen resolution to your liking. This should solve your problem.
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
Mode button unresponsive in my 2006 dodge dakota radio.
After sitting all day in the parking lot at work, I started the truck to go home and everything seemed back to normal. There must be some sort of time related reset. I have not tried pushing the MODE button again and probably won't until I need to.
Nov 04, 2008 | 2006 Dodge Dakota
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Machine will not start.
Hi I am not an expert but, have you looked to see if the pressure swithch is blocked?
Oct 04, 2006 | Zanussi WJS1265W Front Load Washer/Dryer
Apple iPod nano Logo
305 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
