I have a 60GB ATA/133 HDD How do I set it up for an AMD K-7 motherboard (jumpers would be for master hard drive
WHAT hard disk brand?
is your HDD a slim type? or the strandard
for hitachi, ibm, exeltor brand
change your jumpers to........ LIMIT CAPACITY probably 40gb reading.....
Posted on Apr 25, 2008
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
I have placed this hdd into an external case to use as a portable drive but when i plug it in to my laptop (mac book pro) it starts to beep. Windows is installed on the portable drive i was hoping to plug...
at ATA hard drive there is no master or slave, if you want to make it master connect it at ATA slot 1 at mother board, and if you want to make slave connect it at ATA 2 at motherboard
i hope this helpfull
Jan 19, 2011 | Seagate MOMENTUS 5400.2 - HARD DRIVE -...
1.I have 2 Hard Disk instal but BIOS not detect any HDD 2.I want to instal XP but is say not detect Hard Disk. 3.Sorry for my englesh.
HDD2 implies there must already be an HDD1 in the system, unless the number refers to either the ATA-133 or the SATA connections.
If you are using the ATA-133 (parallel IDE) connection for your hard drives, make sure that either both drives have their jumpers set to "CS" or "Cable Select", or one drive is set to "Master" and the other to "Slave". For a single drive, set it to "Master" or switch to the other connector on the cable if you prefer "cable select". (The connector on one end farther away from the other two connectors must go to the motherboard to use "cable select".) Otherwise only one drive will be recognized.
Check the power and data cables to make sure they are properly installed - on some drives it is possible to put the data cable on backwards, but it won't work. The colored wire on the edge of the ribbon cable should be next to the power connector. Also, sometimes the wires work loose from the contact forks inside the connectors. If you think this is the case, run your finger across the cable next to the connector with light pressure to make sure all of the wires are pushed down into the forks.
If you are using the Serial ATA connections, make sure both the SATA cables and power connectors are properly seated.
If you still cannot see the drive in the BIOS, it may be defective, or the motherboard may have a problem with the drive interface electronics (this is much less likely than a bad hard drive).
Once you have both drives recognized, you should be able to partition and format them as needed before you install your operating system.
Jan 11, 2011 | Soltek SL-KT880E-RL Motherboard
Gigabyte-GA-8S648FX I updated my BIOS and my pc wont start, please hel'p bobonickelson@yahoo.co.uk
Ok, you have 2 x UDMA ATA 133/100/66 Bus Master IDE ports on that motherboard, so you can support 4 ide devices. It is important that you split your devices between the 2 available ide channels (each channel has a seperate ribbon cable). For example if you have 1 hard drive and 1 cd drive you'd want to place each on a seperate channel. If you have 2 hard drives and 1 cd drive it's best to place each hard drive on a seperate channel and the cd drive on the same channel as one of the hard drives. You have to make sure the jumper settings on the drives are correct (1 master and 1 slave) when placing 2 drives on the same channel for example. Most likely your jumper settings are not correct and are causing this problem. The jumpers are located on the rear of the drive near where the power cable is plugged into the drive. Most hard drives have the jumper setting printed on the hard drive. Once the jumpers are correct you should be ok.
Jul 05, 2010 | Gigabyte GA-8S648FX Motherboard
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 Hard Drive ATA/133 HDD Internal HD not reconizing in any computer .think it is not getting any power to HD so the PCB Board i think might be gone.any help be...
Power comes from the power supply. Check yellow and black and red and black. You need both 5v and 12v. Are you sure you have the jumper set correctly for the application? Master or single - master with slave present or some computers require CS (cable select)
Dec 05, 2009 | Maxtor Hard Drive
What 2nd "Slave" hard drive should I buy to match my "Master"?
Any size hard drive should be compatible, but you should get the same connection type and bus speen if possible (ATA/133). If you get one from a different manufacturer, you'll have to install the bios update that comes with it and set the jumper to slave per the instructions that invariably come with any "add-on" hard drive.
Dec 29, 2008 | Mobile Rack - 3.5 Inch Hot-swappable...
Gigabyte 8S648FX-RZ Motherboard has problems running multiple IDE devices
May 03, 2008 | Computers & Internet
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Hard disk installation
Bummer I couldn't even find that MB on Gigabyte's site, however a more to the point question for you would be: Are you going to use a XP operating system? If yes than down load the drive's Mfg disk software. Usally you can than creat a boot disk to setup your drive. Pay attention to the jumper settings listed on the drive. If its a PATA drive = serial ATA-133/66/33 you will need to set the jumper for a master or slave or master with a slave. If its a SATA and your board supports SATA II you will need to remove the jumper to allow up 3.0gig transfer rates. If your board does not support SATA II than leave the jumper on. If your board does not support SATA I = 1.5gig tranfer rate, than you can not use this in your system.
Dec 04, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Computers & Internet Logo
43 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
