The scrren keeps saying c drum life, y drum life, m drum life and tray 1
  • 57 Answers
The drum life errors refer to how much use is left on the printer ink cartridges. They're usually followed by a percentage. The tray 1 error might be a paper out error.
Posted on Apr 25, 2008
Orange blinking light hp laserjet 1600
this signal issue mean any paper jam or toner cartridge end remaining or end of drum, transfer belt life
Jul 12, 2014 | HP LaserJet 1600 Printer
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
I have this model printer (brother mfc-7840W) and i'm getting an error on the screen-it says Drum Error. See troubelshooting and maintenance chapter in the user manual
If you have the manual follow the steps for trouble shooting.
It will tell you to remove the drum, remove toner, clean corona wire and reinstall. If that does not solve the issue it will recomend replacing the drum. You can check your drum life by going to menu- press machine info, choose option 3 drum life and press ok. This will show you the remaining percentage of your drum if the number shows less than 25% replace the unit.
If it shows more than 50% you can reset the drum counter allowing the machine to read it as a new unit.( Bare in mind this will change the usage meter back to 100%, you will have to keep an eye out for print defects or light pages as this will signal the end of the drum life) to reset page counter remove the drum from the machine, with the front door open press Clear/back until the lcd displays reset drum yes? no? press 1 for yes and reinstall drum. The machine will cycle until ready; if this still has not cleared the message you will need to contact brother for a manual reset or service.
Jan 05, 2011 | Brother MFC 7840W Printer
My xbox keeps saying open tray I brought it to a guy twice and no fix everytime I put a game or movie in it it reads and says open tray
Reasons
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
May 08, 2010 | Microsoft Xbox 360 Console
The xbox 360 elites keeps on saying open tray when trying to play
solution:
Feb 09, 2010 | Microsoft Xbox 360 Console
Our xerox M118 showing an error"replace drum cartridge'can any one help me?Plizzz
Hello, Your Xerox has two cartridges - one is the drum cartridge and the other is a toner cartridge. Please check the following I've researched from your user guide:
Replacing the Drum Cartridge
The drum cartridge is a customer replaceable unit. After approximately 55,000 copies/
prints, the machine will display a warning message before the drum reaches the end of
life. Order a replacement cartridge now to insure continuous operation.
Country Part Number for the drum cartridge replacement
All countries 13R589
Removing the Old Drum Cartridge
1. Pull the front cover towards you to open it.
2. Open Tray 5 (bypass tray) if necessary, and then open Cover A while lifting up
the release lever.
3. Lift up the colored lever, and slide the drum cartridge out until you can lift the
handle on top of the cartridge.
4. Hold the handle and remove the cartridge from the machine.
NOTE: When replacing the drum cartridge, make sure that the new cartridge is the
correct one specified for the machine.
Recycling the Drum Cartridge
The drum cartridge is designed to be re-manufactured. To recycle used drum
cartridges, return them to Xerox in the original packaging. Return labels are included
with each new cartridge.
Inserting the New Drum Cartridge
1. Remove the new drum cartridge from the box.
2. Undo the sealing tape and carefully pull out in the direction of the arrow to
remove the black protective sheet from the cartridge.
3. Place the cartridge in position and, using the handle, slide it into the
machine until it clicks.
4. Pull out the cartridge tape completely without breaking it.
5. Push the cartridge again so that it is correctly placed.
6. Close Cover A until it latches and then close Tray 5 (bypass tray).
7. Close the front cover.
Hope this helps. Good luck.
Dec 11, 2008 | Xerox WorkCentre M118 Black and White...
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Close the over
Jul 12, 2008 | Brother MFC-8460N All-In-One Printer
Dum problem
1. Open the drum/toner door on the front of the machine.
2. After the beeping stops, press the button on the line of buttons that says Menue Left arrow set richt arrow and clear button.
3. The menu will say replace drum? 1. yes 2. No
Press the number 1 on the number pad and close front door.
Oct 19, 2007 | Brother IntelliFAX 4100 Laser Fax
Hp colouer laserjet 4500n printer 2nd paper tray dont work when i clear the printer memory it work properly for few day in this printer an error shows drum life low change the drum and tool kit
I would definitely suggest ordering the drum life kit and replace that. A lot of times the tray comes undone from the paper tray holders causing the rollers to not be able to pickup paper. Be sure all the plastic holders are snapped into place on the right paper size setting and check the rollers for dirt, glue or wear.
Jun 07, 2007 | HP LaserJet 1020 Printer
542 people viewed this question
k24674
jasbo
jasbo
