Question about Cameras
It is has been on charge for at least two hours and yet it still will not turn on?
    Scholar:
  • 66 Answers
Replace the battery. It's shot and will no longer hold a charge.
Posted on Aug 02, 2010
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
Dec 18, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
I charged my psp for atleast 5 hours.....but charge ended within 1 hour......what to do??
I'm just restating what you said here first...
You plugged in your psp for 5 hours.
You took it out.
You played it for 1 hour before it turned off...
If this is true, it seems that your battery just can't hold a charge. One solution would be to just buy a replacement battery, but you could try this...
Drain your psp completely. This means keeping it on until it turns off, then turn it on again, leave until off and so on. Just keep turning it on until it stays on for less than a minute.
Charge your battery overnight.
Hope this helps!!!
Oct 07, 2010 | Sony PlayStation Portable (PSP) Console
I fully charge the phone but within 48 hours,even without using it, have to charge it again
Don't panic this is quite normal.
Even when you are not using the phone it is still on and actively connected to your service network. Therefore using battery power.
Actually to get 48 hours from your handset is very good.
Normally you would have to re-charge the 81xx series at least every 24 hours.
I was charging mine every 12-14 hours.
Jul 27, 2010 | RIM BlackBerry Pearl 8100
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
Battery Charge - First Use
My experience was similar to yours. The LED turned green after about only 2 hours. Because I didn't want to stay up until midnight to start playing with my Axim, I took it out of the cradle after the 2 hours and everything was fine. Besides, having downloaded and read the user's guide 2 days before receving my Axim, I knew that a green LED meant it was ready to go. 3 days later, everything is still fine and seems normal. A year ago, I received a Palm with similar initial charging requirements, and it also didn't take as long as the directions said it would.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Cameras Logo
12 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
