Question about Samsung SyncMaster 400PXN LCD TV
No power but fuse ok
Samsung 400pxn no power att all but fuse ok
IF it is making a clicking noise it is the SUB PSU , the one that powers the embedded PC, there are 2 CAPACITORS on the PCB that will be domed at the top a 1000uf and 1500uf, they are on the secondary side , this is a common problem with this and the 460PXN (same psu) replace caps with higher voltage rating is my advice,!!! I did everything OK!!
Posted on May 08, 2008
Hi ; I have SAMSUNG HCN436W and it have no power at all when i power it on I get the timmer light flashing. I was thinking it's the fuse; but I cheched it and it's ok. I was thinking it's
Unsolder both chips and look for pico fuses on that board going to the chips---if set comes on with chips out of the circuit then one o f them is a bad chip.
May 04, 2012 | Samsung HCN436W 43" Rear Projection...
CANNOT REMEMBER MY PASSWORD FOR MY ATT SAMSUNG SGHA127 PHONE HOW CAN I GET INTO MY PHONE
  • First contact ATT for an unlock code. You will then have to do the following steps.
  • If you don't know the EMI for you phone, put in *#06#
  • Power on without SIM
  • #0111*unlock code # (unlock code = 8 digit number)
  • Device should say: Personalization Cancelled
  • Phone may automatically reboot
Mar 07, 2011 | Samsung Computers & Internet
My new samsung 400pxn wont turn on it just keeps on making a continues clicking noise every 2 to 3 seconds and the power lights flicks on and off
This tv still under warrenty?Call Samsung for service.Ur tv the power supply board is dead.That the board where the power a/c cord plug into it.That is ur tv power supply board and is dead.It must require replacing.Tries websites like Shopjimmy.com,ebay.com to buy a refurbish power supply board for the replacemnt,if the tv is out of warrenty.
Jun 17, 2010 | Samsung SyncMaster 400PXN LCD TV
Vr357 no power
If you take the top off of the unit there should be a glass fuse right behind the power chord. If you have a multimeter you can check and see if the fuse is ok by setting the meter on 120 ground the black wire to the chassis and put the red probe on the fuse out side to check for power. If the fuse is bad you can replace it, but you may have to unsolder it.
Jan 21, 2010 | Samsung DVD-VR357
I have Att Uverse and a Samsung LCD. We have
If your using the IR remote, the actual colors of the tv are what is causing your problem. What I have found to solve this is go to your local ATT corp. store and order the RF remote this will solve your problem. The techs don't carry these on their truck.
Jan 01, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
Generac NP 50G wont crank
Measure voltage drop across the far ends of the fuse wiring (should measure zero), as one of the wires or it's connection to either end of the fuse may be open. Check the battery negative grounding connection at the frame. If all ok, you may need to find a wiring diagram for the machine. Does this unit have a low-oil-level switch which will kill the engine if set?
Oct 28, 2009 | Electrical Supplies
Microwave is plugged in, but getting no power, circuit ok, cannot find a fuse on the microwave.
Normally if no power is indicated, it is due to a blown fuse but if fuse has blown be careful, it because there is something wrong. Mostly its due to a problem in the power circuit.Can either be the magnatron or the diode capacitor combination.Normally the capacitor goes faulty causing the HV diode to blow. Replace the two components(diode and cap.). If it happens again replace the magnatron. Microwave truely dangerous and needs proffesional att. email me if you want to go ahead yourself
jenfou@teikomsa.net
Sep 21, 2009 | Maytag MMV1153A Microwave Oven
SAMSUNG 400PXN MONITOR IS TURNING OFF AND ON ALL THE TIME
your high voltage power supply in the monitor is probably failing.
you will need to take it to a service center.
Apr 18, 2009 | Computers & Internet
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Emergency call only
give phone a reset.....or change network settings..
Oct 18, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung SyncMaster 400PXN LCD TV Logo
405 people viewed this question
Henry  Thomas
Henry Thomas
