Im looking for i.q. test with answers - Computers & Internet
    Sniper:
  • 56 Answers
Here u can get IQ test with answers....http://www.knowledgebase-script.com/demo/article-467.html
Posted on Aug 02, 2010
I have a 1998 murcury mountaneer the horn does not work .i get a clicking from the horn relay,i ve check all the fusesunder the hood allso,when you use the remote door lock the lights will flash but...
You unplugged the horn & put battery voltage directly to it,
to test it,correct?
The horn relay can click on the coil side,but that doesn't mean
the power contacts are good, but you removed that & tested it also,
correct ?
So why are you lost.
How do you check things like fuses,you use a volt meter,
look at them held up to a light,continuity test ?
Oct 31, 2014 | 1998 Mercury Mountaineer
Rough idle & stalling at a stop
This maybe due to a dirty Idle Air control valve or a throttle position sensor. YouTube can provide good answers for removal and testing of the Throttle Positon Sensor (TPS) as well as cleaning the Idle Air Control Valve (IAC)
Aug 19, 2014 | 2005 Suzuki Forenza
What is the fuel pump pressure for a 1991 eagle summit
the question you ask is legit. unlike other answers seen here.
op , no engine stated
you do know that EFI systems vary by ENGINE, right?
and did you know that Isuzu sold the last car in usa with a carb in 1994? hark.
are you in USA?
log in to mitchell and read?
http://www.eautorepair.net/Marketing/Default.asp
the summit is a rebadged, Mitsubishi Mirage.
the 91 may have the 1.5L 12valve, engine.
ill now log in for you, to get a real answer, USA car.
you gave no symptoms, so cant really help. only
answer the PSI question.
the isuzu page has no data, so im looking it up in Mirage page
the correct answer is
48psi
but the FPR regulator sets that, and varies by
the FPR is located on the Fuel rail, in 1991
and is vacuum controls, if you read the FSM book or link above.
youd see how to test the pump and the FPR.
This EFI engine must have corrrect fuel pressure at idle
and wide open throttle. or EFI will inject wrong.
this is a basic, EFI MPI injected engine, no carb.
The ecu can not read fuel pressure (like 2016 can)
and will not correct for errors.
48psi is key on pressure, and when the engine starts
the pressure drops about 10psi. (vacuum caused)
there are many tests.
leakdown.
injector balance tests
FPR tests, I do 3 tests here, ask.
pump shunt test.
ask.
proof, note there are 5 engines in 1991, see?
Jun 29, 2014 | Isuzu Trooper Cars & Trucks
Would low on freon cause my compressor not to turn on?
you need to check the compressor clutch first it should come on automatically low Freon wouldn't stop it from coming on but im not an exspert on this system. so with out looking and doing a couple of tests cant give you a definite answer. check the breaker first thing. [fuse]
Apr 22, 2014 | 1998 Chevrolet Cavalier
Trouble codes U1110 U1120 U0416 P0309
what engine? v 10?
what is the question, non was asked
did you look them up in the fsm yet> if not why not look first?
factory service manual,
or alldata.com
each has a meaning and more test to find true cause.
same answer all cars., look, read, read how it works , then do tests
to isolate and diagnose why its happening.
or get it serviced.?
learn to do it, or get someone who already knows how.
ill do the 1st one (not all , im to lazy today)
if you learn to use google , you will see others have this. why not look.
309 is misfire#9 ( a v10 engine)?
u1120 is data comms loss, you need service.
is the cars battery fully charged, to 12.6 volts rested
is car running right with full power, sad i have to ask this huh?
get it serviced, or read the FSM on all codes and see that you cant
proceed with out a scan tool, right>?
May 11, 2013 | 2008 Jeep Compass
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Trouble with the car starting it has 55000 miles on it. it eventually starts after turning it over 2 or sometimes 3 times. im thinking it must be the spark plugs
Im not sure if that is the issue or not. It is possible but before I would tell you yes, I would want to know if you have changed the following as it is requested in routine maintenence.
air filter and fuel filter?
routine services? have they been done?
2005 really should not require spark plugs unless you have driven 100000 miles already.
If the answer is yes to all I have written. i would indeed check the
plugs but also consider checking air filter look inside throttle body with the hose off to see if it blackish looking, also try to put some fuel injection system cleaner in your vehicle with at least 3/4 of a tank of fuel.
You may even consider haveing your fuel pressure tested. These are things to always consider when it comes to hard starts.
Nov 04, 2009 | 2005 Chevrolet Equinox
Im looking for an online diagram so i can fix a 96 ford explorer 2wd 4.0liter transmission control circuit solenoid any answers?
Im am looking for a online diagram so I can fix a 96 ford explorer 4wd, 6 cly, 4wd transmission control circuit solenoid and answers
Oct 30, 2009 | 1996 Ford Explorer
RSB? What Does This Mean??
Probably ABS and that means the controller, cabling or a reluctor is not working. The ABS will not work in this condition.
Sep 23, 2017 | 2006 Renault 18I
Computers & Internet Logo
139 people viewed this question
Alun Cox
David Payne
David Payne
