Question about Uniden 5.8GHz Dual Cordless Phone
No dial tone on same used replacement phone
My second phone is broke , so my friend gave me his identical phone , but i can,t get a dial tone.
How do i make the phone rom or find the right channel so can it will work for me
If I am not mistaken, you go to menu and scroll down to deregister the handset. After that, try reregistering it in the vicinity of the phone with the phone cord plug.
Posted on Aug 02, 2010
Caller gets engaged signal. I get no dial tone, dial number is dead / does not ring.
take the phone to a friends/neighbours and plug in to test for a dial tone
if no tone , have the phone fixed
if there is a dial tone call the service provider and ask for a repair to your line
Oct 18, 2017 | Lands Phones
Panasonic DECT 6.0 shows "in use" but it's not. Why?
When I get this error, it's often a problem with the phone line wiring. Sometimes, it is the phone itself.
I like to use a spare corded phone and a new RJ-11 cord to localize the problem. First, try using the spare phone at the jack where the Panasonic base is plugged in. If you get a dial tone with the spare phone, try the new RJ-11 cable with the phone. If there is still no dial tone, then the phone needs repair or replacement.
If you do not have dial tone with the spare phone, try the test phone at another jack on that phone line.If there is dial tone, there is a problem with the first jack. You will need to open the jack and check the wiring. These are either keystones jacks or screw terminals. The keystone type require a special tool to press the wires into the terminal block. This is available at many hardware stores in the electrical wiring aisle (with the keystones and wires for whole house video/telecommunications access).
If you still have no dial tone, find the telephone access box. If you are lucky, that box has RJ-11 jacks so that you can test the line. If there is still no dial tone, contact your phone company. Outside line problems will be fixed by your provider.
If you have dial tone at the access box, you have a wiring problem somewhere inside.You can try to track the wires in any exposed area for signs of damage. You might want to call a professional to check the wires in the wall. Your phone company will do this for a fee.
I hope this helps.
(my own phones gave "Line In Use" when a contractor damaged a wire digging in the wrong spot and when mice got to the underground lines outside. Those problems were fixed by the phone company.)
Jan 29, 2013 | Panasonic DECT 6.0 Expandable Cordless...
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
    Resetting the voice message waiting indicator
    When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
    voice messaging system, you can manually reset it back to the "No messages waiting" state.
    1. Press and hold FiND on the base for five seconds.
    Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
    2. A beep sounds and the message alert tone is reset.
    Changing the dial mode
    Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
    1. Press MENU/SELECT.
    2. Select the Global Setup menu, and then the Dial Mode submenu.
    3. Scroll to highlight Pulse.
    4. Press MENU/SELECT. You will hear a confirmation tone.
    If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
    Finally for future ease of use, here is a link to the user manual were I copied the above information from:
    http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
    Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
    Phone won't transfer to next free line when a second call comes
    If you are not getting a dial tone then something is holding the line off hook. Disconnect any other device you have on your lines and check to see if you get your dial tone back. If you still have no dial tone unplug each phone and check again. You may have to disconnect everything for a minute or two so the phone company will reset its equipment. Plug in your phones one at a time and check your dial tone every time you add something new.
    If you add something and you loose your dial tone immediately you may have a crossed connection in the wall socket, any splitters or in the phone plug. Check to make sure all of the wires in those sockets are straight before you plug in your phone wire.
    If you add your CC machine and everything is good but it fails after you run a transaction you will have to contact the supplier of your CC machine. It is not hanging up the line.
    Mar 22, 2010 | Panasonic KX-T7730 Corded Phone
    How to program speed dial on T7208 telephone?
    Programming
    memory buttons
    External autodial
    1. If you are on a call or an open line with dial tone, press Hold
    or Rls
    2. Press Feature * 1
    3. Press a memory button.
    4. Dial the external number.
    5. Press Hold to store the number.
    6. Label your new button.
    Internal autodial
    or Rls
    2. Press Feature * 2
    4. Dial the internal number.
    5. Label your new button.
    Features
    or Rls
    2. Press Feature * 3
    4. Press Feature and the feature code.
    Erasing memory buttons
    or Rls
    3. Press the memory button you want to erase.
    4. Press Hold to erase the button.
    Feb 13, 2010 | Nortel Meridian M7208 Corded Phone
    Cant get one of the phone to get dial tone says unavalibel
    All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
    Jul 17, 2008 | GE 25931 Trio Cordless Phone
    VoIP not working after modem replaced
    It is possible they have your modem in an internet only class- I would call them and verify the modem is in a class avaiable for phone.
    Apr 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
    Ge 900 MHz cordless phone set on rotary dialing
    Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
    Sep 29, 2007 | Uniden Cordless Phone
    Uniden 5.8GHz Dual Cordless Phone Logo
    44 people viewed this question
    Top Uniden Lands Phones Experts
    k24674
    Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
