Question about Hilti TE 7-C 120V Rotary Hammer Drill
Amount of oil
How much ioil do you put in a TE 72
    Scholar:
  • Hilti Expert
  • 123 Answers
Around 50cc's if it is still wet. 70cc if dry inside
Posted on Aug 04, 2010
What type of motor oil does a 2001 Kawasaki 1500 classic use. and how much does it take to change it
you can use 10w30 or 20w50 motor oil. in any bike I`ve owned from a 72 Honda 350 to a 88 Goldwing 1500 and serviced bikes into 2004 I`ve used 20w50 Castrol motor oil without any problems at all. the amount your bike will need is marked on the case where you put the oil in. I think its about 2-2.5 quarts with an oil filter change.
Sep 18, 2014 | Cars & Trucks
What is the correct forkseal oil amount for a 1982 honda 750 nighthawk
Call the dealer or look up a specific website-Chassis part aftermarket companies generally have this info handy,contact your fork oil company and inquire...
Aug 07, 2014 | All Balls Fork And Dust Seal Kit Husqvarna...
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Where s the ioil plug to change drain the oil
Normally on top size of a Nickle and unscrews. It is not underneath like a car.
May 08, 2011 | Mtd 22" Yard Machine Push Mower
Can i use any 2 stroke oil in my husqvana
Yes, as long as it is a good quality oil. Some manufacturers recommend less oil in the fuel if you use their brand of oil, but using a branded make will not be detrimental unless it is a cheap make. Just watch te amount of smoke coming from the exhaust, it should not be excessive but should also just be visible in the sunlight.
Apr 11, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have hilti te 72 it works but will not hammer
More than likely the con rod is broken. To check remove the shift lever on top by removing the center phillips head screw. then with internal snap ring pliers remove the snap ring.put your phillips screw back in with out the shift lever. Take a pair of pliers and grab the screw and pull the shift boss out. You then can see if the con rod is broken or not. The bad news is those parts are hard to come by.
Dec 15, 2010 | Hilti Drills
How much oil to put in forks of my 1999 TE 610 Husqvarna?
You don't mention the type of your engine.But to make it easy for you to determine oil capacity, find the dipstick that gauge the oil level and you will see markings inch away from the tip.there is maximum and minimum level mark on it.
Sep 05, 2010 | 2000 Husqvarna TE 610
HILTI TE 72 STOPPED HAMMERING BUT STILL WILL DRILL
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Mar 07, 2010 | Drills
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 7-C 120V Rotary Hammer Drill Logo
488 people viewed this question
Top Hilti Drills Experts
John Trevino
Marvin
Marvin
woodzowl307
Are you a Hilti Drill Expert? Answer questions, earn points and help others
