Question about Goodman CKL60AR60 Air Conditioner
Problem for Goodman CKL60AR60 Air Conditioner, what should be the right pressure on low /high side
    Scholar:
  • 80 Answers
R22 boils and flashes from liquid to vapor inside the evaporator coil. This change of state happens at around 40 degrees. Any heat that is gained in the refrigerant from that point of 40 degrees is called SUPER HEAT!!!!! You want at least 10 degrees and not much more then 15 degrees by the time the refrigerant in its vapor state reaches the inlet line at the compressor! This translates to around 50 to 55 degrees as it enters the compressor. This temp relationship can be related directly to a corresponding pressure with a known refrigerant and a T/P Chart!
Posted on Aug 22, 2010
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. If you are talking about r-22 with an outside temperature of 75-80 degress farenheit it should be running between 62-68 on the low side and 200-225 on the high side but there are varibles to take into account like the air flow across the inside coil or a dirty evaporater just things to take into account these pressures are approximate if there are close it should be fine.
Posted on Aug 02, 2010
Low to zero pressure on low side test port
150 is low for high side pressure. may have to add more r-22 to system. if you had a blockage high side pressure should be higher. have you turned both service valves at condensor ccw completely?
Apr 20, 2014 | Goodman CKL42AR42 Air Conditioner
Goodman pgb030075-1 low airflow inside house can i change the fan speed.
the installer selected a fan speed that would be a compromise between air necessary for heat and cool. check what color wire he used coming off fan motor. black is usually high speed.
Sep 02, 2013 | Goodman CKL60AR60 Air Conditioner
A/c wasn't cooling.ice formed on outside lines.had a/c tech check freon level,and was low. he added 3 lbs. cooled for 1 day,now its not as cool .
You have a freon LEAK!!! They need to find the leak and FIX it for you...
Call them back and make them fix it right or call another company to fix it right for you.
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 16, 2010 | Goodman CKL60AR60 Air Conditioner
Goodman Manufacturing co Model ck60-1c serial no 0001496410 , last night my downstairs was coold but my 2nd level was realy hot was not coold air this morning i went outside i found a piece ice on my unit...
If the fan motor on the outside unit is still coming on and the blower motor on the inside unit is still working properly, and your return air is not restricted (sometimes just a dirty filter), then your problem would be the charge in the unit. If over or under charged, the unit will freeze up, not just outside, but inside too. Have someone charge the unit with refrigerant and you should be okay. If any of the other problems exist, it will have to be looked into more. Hope this points you in the right direction. Good Luck!
Jul 07, 2010 | Goodman CKL60AR60 Air Conditioner
Not cooling good
while the machine is running, partially block the outdoor fan until the high pressure reaches 270 psi, the low pressure should be 70 psi at this time. This should be true within 10 lbs.
Jun 24, 2010 | Goodman CLJ42AR49 Air Conditioner
Where is the capacitor located on a goodman 5 ton outside ac unit
right next to the contactor in the side panel where the input 240 volt line enters the outdoor unit
May 24, 2010 | Goodman CKL60AR60 Air Conditioner
Outside compressor and fan motor working properly also airhandler fan motor working but wont cool below 78 and the inlet lines (the small ones ) are freezing slightly on the airhandler coil but the rest of...
sounds like you have a restriction in your metering device, if it is a TXV it has a small screen in it that will capture debris in the system. This is a selaed system problem and unless you have proper tools will require a technician. (probably not what you wanted to heare..sorry)
Jul 19, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman Model CK60-1C with White Rogers mercury tube thermostat
The contactor on the outside unit is sticking and must be replaced. The inside unit cycles off and the outside continues to run causing the refrigerant lines to freeze up.
Jul 29, 2008 | Goodman CKL60AR60 Air Conditioner
Goodman CKL60AR60 Air Conditioner Logo
133 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
