Question about RCA RD1000 Kazoo MP3 Player
Rca kazoo rd1000b
I have an old mp3 player that belonged to my son but it dosn't have a disc to load it on to my computer so i can load music. he erased all the music that was on it and since had it several years ago hehe dosnt know where any of the info is.
i have no disk and computer does not recognize player are there drivers available? ( i am running x p media) o s
  • 3 more comments
  • Jimamania May 19, 2008
    I have found my old RCA Kazoo MP3 Player but no software disc to put any music on it.
    Is there another way?
  • c_djones Jun 01, 2008
    Don't really know what to do to get software or download cd...Thanks
  • reruna1 Jul 08, 2008
    i really appreciate all the info thanks a lot i will try both ways
    special thanks goes out to URZU-7 and
    lupeys
  • reruna1 Sep 12, 2008
    lupeys has a link that is direct to downloading the original disk, however, URZU-7 has a fix for using the kazoo on xp .
    lupeys's link ishttp://rapidshare.com/files/128025756/RC... this will give you the original disk
    URZU-7 gave me this info:
    Ok, before anything, let me say that it just might be a greater convenience
    for you to simply purchase a newer, more user-friendly device. If that
    is not an option, then this is what you can do to upload music to your
    kazoo.
    First, download MusicMatch 8.0 from this location: http://www.oldapps.com/MusicMatch_Jukebo...
    . Before running the setup, you need to set it's compatabilty mode to
    Windows 98/ME by right clicking the file and changing the setting in
    the properties menu. After you do that, run the setup.
    Next, you are going to have to download this: http://members.driverguide.com/driver/de...
    . The file is a .ZIP containing 2 setup.exe files, 2 .DLL files and a
    .XML file. Please note, the site will require you to view a series of
    advertisement before you download the flie, which is somewhat
    inconvienent, but otherwise harmless. Also it says the drivers are for
    the RD1060. Disregard that.
    Run either of the setup.exe files (they both do the same thing so their
    is no need to run both). After that finishes installing, plug your
    device into your PC. Next, you'll need to manually place the two .DLL
    files and the XML file in this directory: Files\MusicMatch\MusicMatch Jukebox\Plugins\Portables\Kazoo_3> (if
    you installed it into a dfferent directory or drive then disregard the
    C:\Program Files). Then go back to ,
    find mmjb.exe and set it's compatabilty mode to Windows 98/ME as you
    did earlier by right clicking the file and changing it in the
    properties menu.
    Everything should be in order to upload. Start up MusicMatch, click 'View' and then click on 'Portable Device Manager'.
    Everything from this point should be self explainitory.
    It should be noted that I did this on Windows Vista, so if it works on this OS it's almost a certainty that it will work on XP.
    both of them will do the job
    all i say whichever you use give them the credit due to them for the answer
    hope this helps
  • Steve Campbell May 11, 2010
    URZU-7- THANK YOU, you totally rock, that worked PERFECT for XP.
    Phoo
That was Great ! Thanks it worked on my windows me.
Posted on Sep 22, 2008
  • 3 Answers
Wow, believe it or not I still have the original cd that came with my rd1000b, and I still have that also, the cd title is Music Management Software from RCA. I gotta find my usb cable to make sure this thing still works.............. cd says says for win 98 me and 2k,,,,,,,,,,,,,,,
whole cd is 90 megs...............
let me know if i can help
lupeys@gmail.com
Posted on Jun 21, 2008
  • lupeys Jul 08, 2008
    here is the orig cd
Apologies for the double post.
Ok, before anything, let me say that it just might be a greater convenience for you to simply purchase a newer, more user-friendly device. If that is not an option, then this is what you can do to upload music to your kazoo.
First, download MusicMatch 8.0 from this location: http://www.oldapps.com/MusicMatch_Jukebox.htm . Before running the setup, you need to set it's compatabilty mode to Windows 98/ME by right clicking the file and changing the setting in the properties menu. After you do that, run the setup.
Next, you are going to have to download this: http://members.driverguide.com/driver/detail.php?driverid=486943&action=filfo . The file is a .ZIP containing 2 setup.exe files, 2 .DLL files and a .XML file. Please note, the site will require you to view a series of advertisement before you download the flie, which is somewhat inconvienent, but otherwise harmless. Also it says the drivers are for the RD1060. Disregard that.
Run either of the setup.exe files (they both do the same thing so their is no need to run both). After that finishes installing, plug your device into your PC. Next, you'll need to manually place the two .DLL files and the XML file in this directory: <C:\Program Files\MusicMatch\MusicMatch Jukebox\Plugins\Portables\Kazoo_3> (if you installed it into a dfferent directory or drive then disregard the C:\Program Files). Then go back to <C:\Program Files\MusicMatch>, find mmjb.exe and set it's compatabilty mode to Windows 98/ME as you did earlier by right clicking the file and changing it in the properties menu.
Posted on May 03, 2008
There is a driver for it that will work with XP, however, the issue is finding a program to make use of that driver. The brain surgeons at RCA decided to not include a program to put music on your MP3 player and instead relied on third party software... that software being MusicMatch Jukebox. Of course, somewhere along the line MusicMatch dropped support and even if one were to acquire an old version of the program, you have to download a MusicMatch plugin that allows it to recognize the MP3 player... a plugin that no longer exists on the MM website. Isn't that wonderful? Currently, I'm looking into the matter, and if I find a solution, it will be posted.
Mp3 player
So you would need a driver fot the ifp-895 or a walkman? which one?
brand and model also, il see what I can find with ifp-895
Jul 12, 2008 | iRiver 7CLIxCRD Cradle for Clix Gen2...
Where do i find a copy or get the software cd to put music on the player
use windows media player, open windows media player and insert your cd and click on the rip tab rip the music to the library the sync it to your mp3 player enjoy
Sep 26, 2009 | RCA RD1000 Kazoo MP3 Player
RCA RD1000B With Windows Vista Home Premium
como puedo descargar musica de mi pc si no tengo el diaco de instalacion
Sep 06, 2009 | Audio Players & Recorders
DELET AND LOAD MUSIC
Plug it into any usb port on any computer. The unit should mount as a removable drive in "my computer" delete only the MP3 files, as some of the others may be software for operation of the MP3 player. Rock on!
Apr 04, 2009 | RCA TH1101 MP3 Player
Need instrutions for my mp3 player M202E
Try music management software that still downloads from libraries like
RealPlayer, Winamp. If you can load your device to it, can manage it through that.
Nov 29, 2007 | RCA Lyra RD2212 MP3 Player
Lost c.d.to program computer to down load song's where can I GET A NEW ONE????
get it here: http://members.driverguide.com/driver/detail.php?driverid=486943&action=filfo
Nov 02, 2007 | RCA RD1000 Kazoo MP3 Player
BAD OR MISSING SYS FILE AND WHEN I TRY TO FIX IT IT SAIDS NOT ENOUGH FREE SPACE WHEN THERES NOTHING ON IT
I bought a 2gigabyte sd card and put music to it and got the same problem turned out the my lyra only can go up to 1gig sd card my rca kazoo only would go to 512 and get the same problem so check to see what your player can go up to
Oct 10, 2007 | RCA Lyra RD1080 MP3 Player
RCA RD1000 Kazoo MP3 Player Logo
1,358 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
