Question about Emerson Televison & Video
I have model # Lc200em8 I wall mounted the tv and now have taken it down. I discarded the base for it, and wanted to know if I can purchase a new stand for it.
  • 346 Answers
SOURCE: Samsung 42" SP-R4232 turnes off and wont turn back on.
check the relay
Posted on Dec 23, 2007
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
bernardlunda
  • 318 Answers
SOURCE: Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Posted on Mar 26, 2009
SOURCE: how to remove base support from PROSCAN LCD TV( model 26LB30Q)
Remove the srews under AUDIO-L/R and HDMI-1.
Posted on Mar 30, 2009
  • 15 Answers
SOURCE: Weight of TV...in order to select proper wall/ceiling mount
Quick solution:
Weigh yourself on a scale. If you can, pick up the TV and step on the scale again. The difference between the two readings is the weight of your TV.
Posted on May 16, 2009
I HAVE A LN-S4095D TV THAT WAS WALL MOUNTED NOW I WANT TO GET A STAND THAT WOULD SUPPORT THE TV ON A TABLE. I DISCARDED THE ORIGNAL STAND WHEN WE WALL MOOUNTED THE TV
Good luck with that. As soon as these sets go out of production, so do most of the parts associated with them. You would be better served to get a TV table stand that uses a wall-mount-style backer. That way you get the tabletop mount and the extra security of knowing it won't get knocked over easily. Something like this....
Aug 10, 2016 | Samsung LN-S4095D 40 in. LCD HDTV
I purchased an element electronics 32" Full HD digital LCD from Walmart with a Ready Set Mount LCD/Plasma Wall Mount, however the mount does not attach to the tv at the base. Do you know if this is...
The wall mount is not made to be fit into the base, it is attached to the back the TV, TV uses what they call VESA mounting which had different pattern for each TV. Look at your TV user manual to find out the VESA mounting number.
If you want TV wall mount that can swivel you can try looking here: http://www.mountsdirect.com//index.php?cPath=1_4&osCsid=b3fd26fc27f668e207c3741b09abfe51&gclid=CJrL-5Dx1acCFYrs7QodUiUq9Q
http://www.toptvmounts.com/collections/swivel-tv-mounts?gclid=CK7kzPrx1acCFYXu7QodlFc4-A
Or Google "swivel wall mount"
I got my from COSTCO.
Mar 17, 2011 | Element Electronics FLX-3211B 32 in. LCD...
Remove base to wall mount
Place the TV face down on cushioning. There are four short hex head screws that hold the TV to the stand. There are two on each side of the mounting point (close to the bottom of the TV). (Turn counter-clockwise to loosen.) Next slide the base down from the bottom of the TV. The appropriate sized hex key was supplied with the TV (and the base was installed). If you want to, you can unscrew the support post from the base - it has 4 long hex head screws. This will let you put the base parts into an appropriate container for storage.
For a clear picture, see the manual for installing the base and work the steps in reverse. See here for a copy of the manual: http://www.managemylife.com/mmh/owner_manuals/search?query=LC46SB54U+ .
To put on the wall mount, you will need to remove the covers from the 4 mounting locations on the back of the TV and use the screws from the wall mount bracket kit.
I hope this helps.
Sep 16, 2010 | Sharp LC46SB54U 46 in. LCD TV
Need base for Insignia TV
It will either slide out from the front/back or to the side..Some actually bolt on from the bottom using screws/bolts.And then again some are not meant to be taken off.Make sure it is a wall mountable tv.Then try to take the stand off as directed.
May 29, 2009 | Insignia LCDTV26 26 in. Television
I want to mount the Mintek D373 on the wall.
There are four screws on each side of the back of the TV(toward the bottom) - You have to remove those.
Apr 05, 2009 | Mintek DTV-373-D 37 in. LCD HDTV
Akai 32"
I just purchased this unit and briefly looked at removing the stand though I haven't taken it off yet. Anyways, I think you need to remove the black metal mounting frame from the TV before trying to unscrew the stand (4 screws) from the metal frame. After the frame is off the TV, I think you can then get at a couple of hidden screws to remove the stand from frame. I don't know if the frame goes back on the TV or not.
Dec 01, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
52 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
