Question about HP LaserJet P3005n Printer
49.460E Service Error ...and when it come on it freezes with a diplsy "ready", but could not respond to any key buttons.
  • 152 Answers
Hello, 4 Errors in HP Laser printers are very difficult to resolve, since your printer is "freezing" likely the formatter board will need to be changed. For more information and troubleshooting guide, follow the posted link.
Support 49 Errors CLICKHERE
Posted on Mar 05, 2011
ERROR CODE e000001-00010
Thsi is an error code dealing with temperature of the fuser assembly. . Try resetting the error code by going into service mode: Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. You should be in service mode. If not press the reset key serveral times to make sure everything is reset and try getting into service mode again. Press the " COPIER " button on the display and the screen changes. Press the " FUNCTION " key across the top of the display and then " CLEAR " then " ERR " and finally " OK ." You have cleared the error out of the copiers memory. Turn off the copier waits a few seconds then power back on. If the error comes back then you have to have the fuser assembly either rebuilt or totally replaced. Good Luck.
Jul 31, 2012 | Canon imageRUNNER 5000 Copier
My dell vostro 1015 laptop freezes intermittently. when this occurs, all buttons and the cursor will just freeze (fails to respond). i then had to force shutdowm by holding down the power button for 5secs....
When does your system freeze? Shortly after booting or my this be an overheating problem? When Laptops / PCs core temperature is too high they tend to stop responding. Maybe it could also be a driver related problem. Can you reproduce the error or is it happening only when you browse certain websites, etc?
Mar 02, 2011 | Computers & Internet
Keyboard freezes up and none of the keys work. I have to shut it off (re-boot it, basically). It's good for about 2 hours and then freezes up again... It also is not consistent about answering the fax...
This is due to a formatter failure.
Try an nvram
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, if within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Aug 11, 2009 | HP Laserjet M2727nf Multifunction Printer
Sharp copier model no. DM1505, will not copy
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
May 17, 2008 | Sharp Office Equipment & Supplies
HP Laserjet 1320 Printer doesn't respond
Manual Feed or Continuable
Error
This state can be reached in
the following circumstances:
● Manual feed
● Out of paper for the
specified tray
● General continuable error
● Memory configuration error
● Personality/Job related
error
Solution
To recover from the error and
print whatever data is possible,
press the GO button.
If the recovery is successful,
the printer goes to the
Processing Data state and
completes the job.
If the recovery is unsuccessful,
the printer returns to the
Continuable Error state.
Feb 05, 2008 | HP LaserJet 1320 Printer
Camera display......
press disp button in your camrea. it will turn ON
Jan 01, 2008 | Canon PowerShot A540 Digital Camera
Cant get rid of blinking error message, nothing works
The correct buttons to push in order to get into the service mode on a 162D are [#] key, [*] key, [C] key and [*] key. Then you key in 14 - 00 and press the Start key. If that fails to bring your machine back on, you'll have to replace the fusing assembly.
Apr 12, 2007 | Toshiba e-Studio162D Copier
HP LaserJet P3005n Printer Logo
866 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
