Question about D-Link Computers & Internet
There is no power coming in Switch from cable, i am putting a power cable in switch's power port but the switch is not working, and light are not working
  • 6,826 Answers
Sounds like the power supply to the switch may be bad, if it doesn't turn the power on.
Check the voltage of the power supply with a multimeter to see what the transformer power supply is outputing.
Posted on Aug 02, 2010
Brake lights not working on my 1985 ford f150 after I replaced the brake switch
disconnect turn signal switch wires @ column, put power to wires to brake lights. that cks wiring to lights. next put power to wires through turn signal to ck switch. Power runs from brake light switch to turnsignal switch, to lights.
Oct 18, 2014 | 1985 Ford F150
I am trying to set up a switch between my PS3 and my PC. I have an external DSL modem. I purchased a 5 port switch(Rosewill RC405-x) but no luck. Can I use an ethernet splitter instead?
You did not explainhaow you connected all your equipment together.
Connect your PC and PS3 into the 5 port switch.
Connect your DSL modem into the 5 port switch, if there is a WAN/internet port on the 5 port switch then connect the DSL model into this port.
You may need to power off the 5 port switch wait a 1 min and power up the 5 port switch again so it can setup an IP address table for the connected ports.
If this still does not work the replace the 5 port switch with a normal 5 port hub.
Mar 20, 2012 | Rosewill RC-405 - Switch - 5 ports -...
We used our Dynex successfully for several months (serving 2 computers) and then, after a big thunderstorm the other night, now Computer 1 internet will only work when plugged directly to the modem....
Thanks for your question.
Given that one computer works and the other does not would tell me to change out cable to see if it fixes the issue, if not then the switch would be the issue on that particular side. Nine times out of ten its the cable itself.
Whichever the case may be you still would be recommended to try another Ethernet cable. Now the lan card inside the computer 2 should also light up when connected, so I would pay close attention to the lan card as well.
Thanks for your questions, We work for your Feedback and ratings, so dont forget to leave some feedback before you leave.
Best of luck
rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 27, 2011 | Dynex 5 Port 10/100 Ethernet Switch...
CSH-800 8-Port Ethernet Switch Problem When i switch the power on, only the POWER LED light up and nothing is happened, computers cant detect it
Switches arnt not detectable by the computer, a switch allows you to link multiple pcs togethers that sit on the same domain/workgroup , and also network subnet, the other lights will come one when you connect a RJ45 cable between the unit and a PC to show a port is in use.
May 10, 2011 | Cnet CSH-800 8-Port Ethernet Switch
I am trying to add an additional PoE device, put it will not power up. How can I tell the switch to power up a specific port, or put the switch into automatic mode?
Are you within the power budget?
Power feeding of Ethernet is limited for fixed 10BASE-T/100BASE-TX ports. The solution can provide maximum output power per PoE port up to 15.4W on 12 ports or 7.5W on 24 ports simultaneously. The Switch provides independent overload and short-circuit protection for each port, LED indicators for power status per PoE port, and supports IEEE802.3af MIB for Power over Ethernet functionality.
For each attached 802.3af-compliant device, the Switch automatically senses the load and dynamically supplies the required power. The Switch delivers power to a device using the two data wire pairs in the twisted-pair cable. Each port can provide up to 15.4W of power at the standard -48 VDC voltage.
Source: http://www.cisco.com/en/US/products/ps9967/products_qanda_item09186a0080a36afb.shtml
Mar 19, 2011 | Cisco Systems 24-Port SF 300-24P 10/100...
My Netgear FS605 stopped working. All lights flashing about 1x/sec. No change in cabling or configuration in past year. Upstream Linksys N wireless router working fine. Tried disconnectring ethernet...
Are you able to ping between systems connected to the same Netgear FS605 switch and in same VLAN.
I suspect either switch port or Uplink cable issue.
Please try changing a new cable and if no improvement then please try with a different switch port.
Jan 08, 2011 | NetGear FS605 (FS605SE) Networking Switch
I have power in 14/2 and 14/2 out to light. how do I wire the switch. I tried putting whites together and blacks to switch but it doesn't work.
Your breaker is not tripped.
Your light bulb is working.
You have a working on-off switch that has two brass screws and a green ground screw.
That is a single pole switch. Black wires go on either brass-colored screw, and whites are twisted together.
If switch has 3 screws and ground screw, connect black wires to dark-screw and one of the brass screws.
First you should test your wires.
You have 2 cables.
Both cables have black, white, and bare copper ground wires.
One cable goes to light.
Other cable comes from breaker box.
Cable from breaker box has black-hot wire and white-neutral wire.
Turn on power and test black wire to white, and then test black wire to ground.
Tester should light up with both tests.
If tester does not light up, then breaker is suspect, or there is a short in nearby box.
Track back the short towards breaker, going one box at a time, each time testing black to white and black to ground.
Next, inside the switch box, remove the switch and connect both cables without the switch.
Black to black
White to white
Turn on power, does light turn on.
If light turns on, your switch is suspect. Connect new switch. One black wire to each brass screw, and then tie white wires togethr.
If light does not turn on, your light is suspect. Open light fixture and test black to white and black to ground again.
If light tests with power, then check your bulb
If light has no power, then wire between switch box and light is suspect.
Dec 06, 2010 | Electrical Supplies
Cant find correct port for pwer sw cable
check the power switch, ensure it works, check the case intrusion switch. also
Apr 11, 2010 | Computers & Internet
I connected an ethernet cable to the DES-1024D switch, but the link/act LED didn't light
Is the switch powered up?
is the Ethernet cable connected to a working/powered/enabled NIC?
Jun 10, 2009 | D-Link DES-1024D Express EtherNetwork...
8 port kvm console switch
KVM switches are hardware based and there is no use software.
Aug 22, 2006 | HP Console Switch (J1474A) 8-port KVM...
Computers & Internet Logo
580 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
