Question about Konica Minolta Riva Zoom 70 35mm Point and Shoot Camera
Where do i purchase spools for this camera? - Konica Minolta Riva Zoom 70 35mm Point and Shoot Camera
    Brigadier General:
  • 3,006 Answers
From almost any camera shop, petrol station, drugstore or supermarket.
35mm photographic film remains widely available.
Posted on Aug 02, 2010
Testimonial: "Although I founf the answer shortly after contacting you I sincerely appreciate your feed back. Thank you. Keep up the good work."
When trying to load film rewinds and motor keeps running and will not move from'0'
First off, what type of camera. Second, at first blush is sounds as though the film leader is not being held by the takeup spool thus film is not winding frame one. That is what may be causing it to continue to run on. If there is film in the camera put the camera in a change bag, remove the film then rewind it into the spool. After removing both from the change bag inspect the takeup spool and the mechanism that starts the film on the takeup spool, it may not be holding it tight enough.
Mar 07, 2015 | Photography
I need help loading film on to a Canon AZ-2900R Automatic
It is not possible for me to find a manual, but the camera looks like my my EOS5oo (film camera, not the digital one)
I still have some film camera's from Canon and the way to put in the film is the same in almost every one, so I give it a try. Make sure you have the correct batteries in the camera. You can check by turning the mode dial to any position other than L and look on the display. If the battery symbol is flashing, it is too low. Turn the mode dial to the L. Open the camera, then put the roll in the left hand space and while holding the spool in place pull out enough film (one to 2 inch) to reach the orange point on the right hand side. Then close the camera.
If you pulled out more film, please put it back in the spool by turning the knob.
As soon as the camera is closed it will spool the film to the starting point. A little spool symbol and the ISO will be visible on the display. When the spool is blinking something went wrong and you have to insert again.
I'm not sure if your camera detects the correct ISO, but if not you have to correct that your self. I don't know how to do that.
I think there is a category for analog cameras too. This one was in digital cameras. Success
Jan 04, 2014 | Cameras
Minolta xg9 camera. Where can I get a take-up spool?
i have a take up spool for xg9. i am located in south africa
Jul 22, 2013 | Cameras
Need to replace the wirefeed? Purchased 8" orange
Hi gramcherry1...
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
Am having trouble loading my Noblex Pro 150E2. Haven't used it in years...is the right hand compartment for the empty film spool supposed to spring load also? Mine isn't and I cannot get the rigid empty...
Does the wind handle lift up like a 35mm camera? Or, some cameras you can just push the bottom end of the spool down and release the top end of the spool.
Apr 28, 2011 | Noblex PRO 150 UX Medium Format Camera
Loud grinding noise when I "****" the film.
kyle_walsh,
does this noise happen with film loaded or all the time?
this could be a broken gear or the take-up spool is slipping. with the film door opened advance the lever and check if the take up spool is turning. if not turning then a gear is broken. if the spool is turning then the spool is slipping.
there are no new parts available for the K1000, however some camera repair shops have good used parts that can be used.
the take-up spool was one of the very few weak parts of the K1000, you can make a temp. repair if you want.
on the take-up spool push down lightly on the gear like wheel and rotate the spool you should see a hairline crack under where the film is inserted. check both sides. if you find the crack put a very small amount of super glue on the crack using a tooth pick or similar tool. this works 80% of the time.
if you take or send your K1000 to a camera repair shop get an estimate first.
Feb 23, 2009 | Pentax K1000 35mm SLR Camera
Film Advance Problem
ksanzo,
The take up spool is cracked at the base causing the spool to slip. The camera must be mostly disassembled to replace the spool ( if available ) . This is one of the very few weak parts in the K1000. send or take it to a camera repair shop for an estimate first. --- or--
separate the base of the spool by pushing down on the gear like wheel and if you find the small crack from the bottom of the spool film slots, very carefully put a dab of super glue on the crack. check both sides of the spool. this works about 80% of the time. however it's better to replace the spool.
Jan 21, 2009 | Pentax K1000 35mm SLR Camera
Black spool that holds tape is broken
Hi.
They tend to be different in each model, so you would need to purchase one from a Casio dealer for that model. either lookup a CAsio dealer in your phone book, or online and tell them you need a paper takeup spool.
Mark
Jan 12, 2009 | Casio Parts Cash Register PC Desktop
Vivitar
be sure that nothing film inside the camera , open back side of camera by pulling spinning knob , put film spool on left side and at the right side insert the film strip on diagonal small hook, turn the spool rachet turning left side then click shutter twice while holding the spinning spool left side , then close the cover , tightened the spinning spool little bit then test shoot.
Dec 25, 2007 | Photography
Konica Minolta Riva Zoom 70 35mm Point and Shoot Camera Logo
51 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
