Question about Tascam CD-302 Version 4.0 Dual Deck CD Player
Buttons Gemini mpx 3 aren't working anymore
The left side of the controlldeck isn't working anymore. All buttons don't work. Only the pitchcontrol is working and the buttonlights work to.
Right is no problem.
Thank you,
Sander from Holland.
It wont power up the lock indicator lights blink 1 time the on buttonlight stays on but thats it
Hi Richard, The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS..
ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
May 01, 2016 | Computers & Internet
Right and left click do not work, space bar slow
Hi
As you said that the Right and left buttons are not working as well as the space bar, then it could be the issues with some dust particle inside the keyboard.
Try to clean it. Try to use it hope it will work , but in case it don't work then you need to replace the Keyboard.
In case if you have any more trouble do contact back in Fixya.
Thank you
Aug 11, 2012 | Sylvania Computers & Internet
I search service manual for Sony vaio CR23
No I don't but it is very likely the left speaker is open, if you have a digital meter set it to ohms, unplug speakers from motherboard to remove any loads and compare readings on both sides. Then check out www.ebay.com Type make and model of laptop, and refine search to speakers.
Jul 02, 2012 | Sony VAIO Computers & Internet
No fluid from rear brakes when bleeding
I don't think the air will work its way to the left side unless your bleed valve is higher than the master cylinder. You'd almost have to hang it up by the rear.
Try it again with only the left side open, reservoir full, and pump like crazy. Fluid is bound to come out unless there is a restriction, either in the line , or the bleed valve may be clogged. I'd bet the bleed valve. Take it off and clean it.
Nov 17, 2011 | 1994 Hyundai Excel
Im looking for the fuse for the right tail light
You do not have a separate fuse for each side, if the left side works, replace the bulb in the right side that isn't working.
Jun 26, 2011 | 2002 Jaguar X-Type
Last night when I turned my tv off it was working fine. I turn it on today and the picture is bigger then the screen itself, and my Video 2 isn't working anymore, it doesn't even acknowledge that I...
On your tv remote click on the "wide" button and change the setting. Also you could try the setting on your cable box that pertains to the size of your screen. If all that fails, go to the website of your tv maker and see if they could send you a manual or give you advice on how to make screen smaller.
Jun 09, 2011 | Televison & Video
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
Okay so my right button isn't working properly i have to hold it down for a while for it to register the right click, I really need help, thank you
The only cause I can think of is a weak battery. If this is not the case, then the mouse could have a bad or dirty contact under the right button.
If you can scroll and the left button works well, I'd lean toward the dirty contacts.
Jun 03, 2011 | Microsoft Wireless Laser Mouse 6000 v2.0
My left pitchcontroller doesn't work anymore. This is since I replaced it to an other room. The rest is still working. How can I fix this?
your problem doesn't make sense, are you saying you moved your iDJ2 to a different room & the left pitch controller stopped working? If so i doubt that has caused a problem unless you droped it or something feel inside the gap where the pitch slider moves. So many iDJ2 problems can be solved by simply formatting it & re-installing the firmware.
Feb 02, 2011 | Numark iDJ2 - DJ iPOD Mixer Docking...
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Tascam CD-302 Version 4.0 Dual Deck CD Player Logo
46 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
