Question about Indesit Washing Machines
My INDESIT W43T washing machine problem is cannot start,water no come in and i check the door also no lock,i try to another stage,only pump water out system function.another stage no function.what should i do?
I have index w43t. it makes some abnormal noise from drain pump and water is not drained. I opened the drain filter and found the noise came from the drain motor. How can i solve this problem?
Posted on Jan 03, 2011
I have a indesit washing machine w43t please operating manual
Posted on Apr 07, 2013
My indesit W43T washing machine has got whole body electrified, what can I do ?
Hi. You have to check if is grounded properly first:
Plug with proper ground
Connecting wire ( does have the metal pin on it ? Have to have it or will do that to you all the time. If this is ok,something indside is shorted to ground. Could be rusty ground,bad connection. Or simply motor is getting shorted to the ground. Sometimes a little bit of water is leaking out and getting on components.
Apr 19, 2017 | Indesit Washing Machines
I have a indesit iwb71250 that the red door lock light is on constantly but we can open the door and shut although the machine will run it wont fill with water... any ideas
May be the switch is loose try fixing it with ascrew driver or the rubber hose is not fixed properly and the machine pump is taking air or the pump failure
Oct 19, 2014 | Indesit IWB71250 White 60 cm Washer Front...
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
A load of wash got "stuck" at 22 minutes left on the wash cycle. I turned off the machine. I turned it back on. Now the door is locked. How can I unlock the door and restart the machine?
Try starting a cycle and then cancelling it. Could also be problem draining. Check pump filter. I have had this twice on my indesit washing machine. You have to take the front cover off the bottom and then unscrew the filter to check it. Be careful as it will gush with water if the drum isn't drained.
Check the drain pipe for blockage by disconnecting far end of it and lowering to floor level (in a bowl). If no blockage then water should drain out of the drum by gravity.
Apr 03, 2011 | Washing Machines
Drain
Check the hose from the pump to the outlet, sometimes it can get blocked.
Make sure you can hear the pump working, you should be able to hear it running.
Hope this helps.
Jan 14, 2010 | Indesit Washing Machines
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
User manual
www.theusermanualsite.com/ex/mfg/.../indesit/.../manual_request
Apr 22, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
387 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
