Question about Blanco 501-107 spex 1 & 1/2 Bowl Drop-In Stainless Steel Kitchen Sink
Plug opener and closer broken - Blanco 501-107 spex 1 & 1/2 Bowl Drop-In Stainless Steel Kitchen Sink
Can I manually close or open roof on 500 sl 2005, stuck and want lower
Some cars have a manual sun roof closer. It's usually in the ceiling in the back seat, behind a plastic plug. Remove the plug and insert an allen wrench to close the sun roof.
May 10, 2015 | Cars & Trucks
I have 2 mintcraft hydraulic door closers and one of them will not close on its own when opened past a certain point, is there a way to fix this?
The problem you have is there is either something inside the closer keeping it from closing or the closer is worn out and has tightened up. You can take the closer off and see if you can get it to work without being attached to the door to determine what is causing the problem. Also if your door is in a windy area then that could cause it to stay open. If you can't figure out what's causing the problem then you can replace the closer with a new one. If i'm not mistaken they run somewhere between 10 to 20 dollars depending on where you go to buy one.
Feb 07, 2013 | Mintcraft Black Hydraulic Door Closer...
Tried a Kodak Extension remote cable and slide transport now inoperative
Take a closer look at the pins on the remote cable and the socket on the projector. Their are 5 pins on the plug. The top 2 pins are closer together than the bottom 2 pins. It is easy to rotate the plug 180 degrees and with little extra pressure, push it in. If the pin / plug interface is rotated 180 degrees, the remote control will appear non-functional. Check that first. Then try plugging the remote into the projector without the extension to eliminate a broken wire in the extension cord. Verify that the on-board cycle buttons will cycle the projector. If they do, and the projector won't work with the remote control, then there may be a open circuit inside the projector. You may need a factory-trained technician to help you with this one!! Good Luck !! Jim
Nov 06, 2012 | Office Equipment & Supplies
I've got a Casio Privia (PX-400R) keyboard and it seems that the pedal jack has gone out. It's the 3 pedal jack circuit board. I took the keyboard apart almost completely to take a closer look at the jack...
Hi genoness1,
If you noticed that the pedal works on and off depending on the jack plug positioning, it is because the jack is already broken loose from the solder on the board. If the pedal that you are using can normally open as most or normally closed like Roland types, you can still replace the loosed jack. Unit has to be opened and correct jack replaced.
Hope it helps.
Thank you for using FixYa.
Apr 19, 2011 | Casio Privia PX3 88Key Portable Stage...
I am having a very hard time removing the heater box to replace a broken blend door. I have removed all screws and nuts and have the dash out. But just cannot get the box out due to the rear air duct. Any...
It can take a professional 5 hours to 10 hours to do the job.
If you have the dash out, then you're closer than most people who work on their broken blend door problem.
Keep on plugging.
(I don't know what car you have but most manuals do not publish this information).
Jul 05, 2010 | Cars & Trucks
Can't open Toshiba laptop case for repair purpose
sometimes on older ones you have to remove the battery and the cd drive and sometimes there are screws there, or in some cases a latch inside where the cd used to be
Sep 01, 2009 | Computers & Internet
Garage door will open with remote control but will not close with it. one led light is solid yellow, the other will not light up on that side of the garage...if i take the 2nd led light to the other side...
When you say you are taking "the 2nd led light to the other side of the garage" do you mean you are connecting it to the other wires or just moving it closer to the other led? If it lights when connecting to another set of wires then the other wires are bad. If it lights when you just move it closer then I think the sensor is bad.
Sep 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Ice maker shute clogs and ice builds up inside door of freezer
the baffle (door that opens/closes) not working properly and allowing moisture to enter or a spring on the closer broken or the electrical solniod is failed, try this get some ice open the frzr door and if the door don't close a repair is in order,,,
Aug 20, 2009 | KitchenAid KSBP25IN Side by Side...
Replace ink now it says close top
Hello, have you placed the inc in right position?, also look for the close lock sensor on your printer, is it open or broken? if its broken you can just set something that holds it in closer position.
Jul 06, 2009 | Lexmark X1240 All-In-One InkJet Printer
Tub has broken off -- can't open front panel to take a closer look
looks like a whirpool model if model # begins with 110 remove 2 screws holding panel above washer lid on back of top either 2 screws or 2 clips both not easy to get to remove them and slide top off and remove wires to lid switch front panle held on by 2 screws on rear lip panel lifts straight up and off shock may have just separated and you might be able to screw spring and body back together ..good luck
Mar 07, 2008 | Kenmore 80754 Top Load Stacked Washer /...
Blanco 501-107 spex 1 & 1/2 Bowl Drop-In Stainless Steel Kitchen Sink Logo
44 people viewed this question
Top Blanco Home Experts
uggachucka
Level 1 Expert
VsaToronto
Level 1 Expert
Tom Chichester
Are you a Blanco Home Expert? Answer questions, earn points and help others
