Ovens Logo
Posted on Aug 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fan works but oven does not heat up - Ovens
sibuor
Level 2:
New Friend:
  • Expert 106 Answers
  • Posted on Aug 02, 2010
sibuor
Expert
Level 2:
New Friend:
Answers
106
Questions
0
Helped
36509
Points
197
Please check the elements, they could be bunt out or the wires connecting burnt , if ok check the relay that supplies it and its fuses
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 • Ovens
1helpful
2answers
Main oven light works fan runs but oven doesn' get warm
ROSIERES Oven not heating? How to replace a ROSIERES fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for ROSIERES element How to Repair Home Appliances
2helpful
ZBF360X Electric Single Oven: fan oven working but no heat...
If the main oven fan is working but no heat it is most probably the ring element which is around the fan blade inside the oven.Check it is the element before you go and replace because there could also be an issue with the thermostat.Hope this helps.
Good Luck,
1helpful
2answers
My candy oven r43/3xuk wont switch on. The power
If the fan is working o/k then it is likely to be a faulty oven element if it is a
electrically heated oven.
If it were the timer, not even the fan would work.
Mar 28, 2010 • Ovens
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
10helpful
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Thanks.
Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
1helpful
Neff single oven
fan heating heating element gone replace it ;Ire close bye
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
