Question about Honda Horizontal OHV Engine for Non Pumps 160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2
Honda GX 160 under 30 hrs from new, is running poorly
Honda GX 160 under 30 hrs from new, is running very poorly, and subsequently not generatinfg electricity; have tried new BPR6 ES spark plug but without change in condition; recently changed engine oil with Honda lube (10W30, surely unrelated?). Suspect fuel? Air filter clean enough, blowing some black smoke out of exhaust when turning over prior to starting before running approx half speed, vibrating a bit and then sputtering and finally stopping. Will now try the fuel sediment cup, but I always have used freshly bought fuel prior to filling/starting generator.
My model does not seem to have a hand throttle lever fitted, only a choke lever, I'm guessing a generator (Pramac 3000 in this case) should not require any modification of running speed once set by the maker? Any suggestions gratefully received, thank you.
  • 30 Answers
Try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Posted on Aug 26, 2010
  • Roy Cagle
    Roy Cagle Sep 14, 2014
    Black smoke out of the exhaust sounds like too much fuel or the valves are out of adjustment. Are you remembering to take the choke off when it warms up?
5.5hp GX 160 only runs flat out wont idle
carburetor throttle plate stuck open or spring off/ stuck on governor assy.
Jun 16, 2014 | 5.5 HP GX160 Engine
Oil Level Sensor Issues
Not worth the work. Just leave it disconnected and check oil twice daily under hard working conditions. Change the oil every 100 hrs of hard use or when it looks black and dirty.
Apr 09, 2014 | Honda Air Tools & Compressors
I have a Honda GX 160 and I an getting gas in the oil
hi under the carb is a drain bowl .shut the fuel off then take the bowl off 10 mm bolt .then you will see a plastic float hold the float up and turn the fuel on if fuel is cuming out the needle might have dirt on it. turn fuel off now pull the pin out that holds float in place the needle will come down with float spray needle and where needle is seated with carb cleaner now re fit needle and float and hold float up and turn fuel on if no fuel comes out problem sorted. drain oil and fill with new oil.if still leaking fuel you need a new needle
Sep 24, 2013 | Honda Horizontal OHV Engine for Non Pumps ...
Honda gx 160 runs for 30 minutes then shuts off and wont re-start
Try checking the fuel filter and or line. Sometimes dirt is drawn in to plug the line, then settles back down later.
Nov 28, 2012 | 5.5 HP GX160 Engine
Where to connect the throttle cable on a GX 31 honda motor FG 100 tiller
I look up honda engines at : honda-engines-eu.com they have the best access to detailed information. If you can identify the carb butterfly, any cable should attach to the butterfly control. I see a Honda GX100, but not a GX31.
Oct 09, 2012 | Honda Horizontal OHV Engine 340cc, GX...
I have a Honda GX 160 5.5 Power washer Model Number: CM2403. What kind of oil should i be using in the engine?
If it has a Briggs engine then use SAE 30 oil. If you run synthetic (which I highly recommend), then SAE 30 or muti-viscosity oil like 10W-30 can be used, but if using conventional oil, only SAE30.
May 25, 2011 | Garden
I have a honda gx 160 5.5 pressure washer. It's hard to start
do a full service on it , new spark plug /air filter foam , full oil change , also chane the oil in the pump end , carefully remove the carb bowl and remove any dirt/rust/water etc
ive seen gx160 engines last 10 years no problem and those were hire machines
hope this helps if it does please vote
Nov 13, 2009 | Computers & Internet
MY GX 240 starts fine runs great any where from 30
Can your gas tank breathe? Is your fuel filter clogged? Might there be something in the tank that would obstruct the flow of fuel?
Check the tank by loosening the top to allow air to enter.
Let me know what happens
a
Sep 23, 2009 | Honda 8 HP Engine
Honda GX 160 quits running at variable times.
a coil wire may be shorting so look for damage on them!
you can sleeve them or a quality electrical tape will be ok for temp measure ok
Cheers Rob.
Jul 28, 2009 | Garden
Honda Horizontal OHV Engine for Non Pumps  160cc GX Series Threaded 58in x 2 716in Shaft Model GX160UT1TX2 Logo
378 people viewed this question
Top Honda Plumbing Experts
rlev_7
Level 1 Expert
Matt Olenzek
Matt Olenzek
Tony Crow
Are you a Honda Plumbing Expert? Answer questions, earn points and help others
