When i double click my yahoo messenger icon on the desktop it appears: YAHOOM-1.EXE- Application Error, The application failed to initialized properly (0xc0150002). Click OK to terminate the application.
Try to remove yahoo messenger and re-install it again.
If you can't uninstall it try this:
1) Log out of Yahoo Messenger and close yahoo messenger completely [ it should not be running under task manager as a process ].
2) Open Start Menu >> Control Panel.
3) Double-click on Add or Remove Programs.
4) Locate Yahoo Messenger in Add or Remove Programs.
5) Click Change/Remove button.
6) Restart your computer, if it doesn't restart it automatically.
7) Open Yahoo folder in Program Files (C:\Program Files\Yahoo) and delete it.
8) Open registry through Start Menu >> Run and type regedit now navigate to the HKEY_CURRENT_USER\ Software\ registry entry, delete Yahoo, and exit the Registry.
If the above method does not work for you, try the following methods to solve the problem.
1. Open Program Files >> Yahoo Messenger and find the file UNWISE.exe file. Double click this to run it. This will un install yahoo messenger.
why is it my yahoo messenger that id download now is failed to initialize properly?
can you please help me the right thing to do to make my download completed?
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
add the Yahoo messenger.exe in Data execution protection (DEP)
exclusion list. This error is comming because you have enabled DEP. I
think it will help you to fix the issue. Thanks for joining Fixya community...Good Luck
Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP)
Hi, YAHOOM~1.exe is the main executable for Yahoo Messenger, the problem is it is crashing. Uninstall yahoo messenger, restart the computer and reinstall yahoo, that should sort the problem out for you.
