Question about Microwave Ovens
I moved into an apartment with Westinghouse Kimberly 501 upright coil stove. A few days back there was a spark and the fuse went off.The electrician diagonosed the issue of having a 16-18amp fuse for this, thus replacing it to 36amp. The next day there was another flash spark and one coil got short cirtuited.He replaced the coil and checked the circuit sys. Today the big coil also gave a flash and is not working. I am concerned on the safety of my family with the equipment,Please advice, can this be serviced or it needs to be done with.
    New Friend:
  • 47 Answers
According to my knowledge, this particular stove doesn't have fuse(s) as such. They have been prone to failure issues with the temperature control regulator which is located behind the control panel. Be certain the stove is unplugged before attempting to work on any part of this appliance.
Posted on May 02, 2017
  • 9098 Answers
SOURCE: GE Spacemaker XL1800 (JVM1860WD 002) Stoped Working.
The control panel has built-in surge protection, and the high voltage probably tripped that. It will have to be repaired, which we do nationwide for only $39.95 postpaid. By rights, I would say the electrician should be the one to see to the repairs, including removing the control panel assembly to send in for repair. We have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams by entering your full model number (without the suffix) here: Please let us know if you have any other questions.
Posted on Apr 13, 2007
  • 9098 Answers
SOURCE: GE Spacemaker Microwave Blown Fuse replaced still no power
If you measure across the varistor leads with it still in the circuit, you should measure around 100-300 ohms, which is the DC resistance of the primary of the low voltage transformer.
If you read infinity / open the primary of the low voltage transformer is bad.
If the varistor is bad, it will be shorted and usually it will be cracked or split. This is a much simpler way to test the varistor.
Have you checked the magnetron thermal cutout (TCO) (or thermostat if so equipped) and the oven TCO? These are the leading causes of a dead GE when the fuse is okay.
You didn't mention the model number. What is it?
Please reply back here if you still need help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
Posted on Jul 18, 2008
  • 9098 Answers
SOURCE: buzzing noise.microwave not working
That's almost always a defective filter capacitor on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
Posted on May 20, 2009
  • 909 Answers
SOURCE: I have a National Panasonic Genius microwave that
That fault is a little tricky. Need to check if you are getting voltage onto primary of transformer. If you are, the problem is almost certainly the magnatron which has gone open circuit. If and when you replace it, change the cap and HVdiode. Wont be sorry if you do. If no voltage there , your board is faulty. replace it.
Posted on Sep 17, 2009
  • 3051 Answers
SOURCE: Microwave Blowing Fuse. Fixed. After Day, Fuse Blows Again.
Hello there:
If you have all ready changed out the fuse and it has happned again i would first check to see that the fuse is the right one for the machine (i am sure that you did this but please recheck ) next i would look at the controle board as the next culprit it maay be failing expecially if there were any pops ar sparks that was noticed before the initial failure.
Also check to see if all of the wires by the board a re not loose or looked burned ar if there is any grease or anything like this around the area
And finally check to see if the plate is turning ok and not sticking cause this would cause the microwave to overload and it wil make every fuse you put in there fail after just a couple of uses ok
SO please try all of these things that i have explained to you
I hope this is very helpful for you.
Best regards Michael
Posted on Dec 12, 2009
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
No power
Your stove should be on its own breaker or have its own fuse. Some models of stoves have fuses within their own control panels too. Check your home's panel to see if a breaker has been flipped or a fuse blown, and follow up with the owners manual for your make and model of stove.
Mar 05, 2014 | Magic Chef Microwave Ovens
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
I have a Magic Chef microwave MCO160UB. I was cooking on the stove (microwave wasn't on) and the fan came on as it has done before. After a few minutes, it shut off and is now completely dead. I...
If the microwave is above the stove, the heat sensors in the microwave
may turn on fans to cool it even though the microwave itself is not
running. It tries to save its life. It should turn off when the stove is not
heating it.
Aug 29, 2011 | Magic Chef MCO160UB Microwave Oven
I have a jenn-air stove The igniter went out on all 4 eyes on the cook-top
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
Dec 25, 2010 | Microwave Ovens
Works fine before unplugging, stops working when plugged in again
Westinghouse WST3504 User Instructions Before Calling For Service
Note: If the Microwave Oven still does not work properly, please contact Service and Repair
located on Warranty page. 19
• Is the power cord plugged in?
• Is the door closed?
• Is the cooking time set?
Feb 01, 2018 | Westinghouse WST3504 Microwave Oven
The built-in microwave went dead as I attempted to screw in a new light. It arc'ed, then there was zero power to the unit. Is there an in-line fuse or circuit-breakers?
was cooking on the stove below the microwave and had the fan on. the nicrowave went out all together and will not come back on. it did not blow a fuse in the breaker box. is there a reset button or something to turn back on
Aug 05, 2008 | Microwave Ovens
Microwave over the stove
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 27, 2007 | Frigidaire GLMB209D Microwave Oven
Microwave Oven completely dead
Check if there's a fuse on the front panel.i'f had it on other makes.replace fuse and it should be ok.
Feb 22, 2007 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
74 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
