Question about Lands Phones
SonyEricsson Z320i Problem start up. Can't turn on if left off for a while (battery is . If remove the battery and put back in place, sometimes start again???? Thank you
  • 2 more comments
  • Anonymous Mar 10, 2009
    Same problem here
    same thing here. In the beginning removing the batery worked, but now even that doesn't help any more.
  • Anonymous May 22, 2009
    Problem is hard to turn on the phone
  • Anonymous May 24, 2009
    i cant even start the phone but i can charge my batteries? wtf?
    President:
  • 1,944 Answers
Key won't turn, won't shift from Park
My 2003 Saturn l200 2.2 ecotec did this when the battery was dead. Put some juice on the battery, then the car came out of park, and I was able to remove the key. To the car, there's a vast difference between a sluggish battery and a dead battery. It may have enough amps to crank it, but it wont start w/out full output from the battery.
Apr 12, 2013 | 2004 Chevrolet Cavalier
My sony ericsson z320i mobile will not turn on. i have tried charging it for a fiew hours, a light does come on but the mobile itself doesn't.
First remove the mobile battery the re insert it again
Next ,press and hold and the C button with the Power button at the same time,it will turn on
Jun 05, 2011 | Sony Ericsson Z320i Cell Phone
How to replace light bulb on a clock 2004 Honda Odessey
Here are the steps:
1. Undo the panels to the left and right of the steering column.
2. Remove the panel that encloses the instrument cluster.
3. Replace the light bulb located on the back of the panel (removed in step 2).
4. Reinstall the instrument panel (removed in step 2).
5. Reinstall the panels on the left and right of the steering column.
Here are the details:
FIRST - Disconnect the battery. Be careful to locate the radio security code and radio station memory locations before you disconnect though. I chose to disconnect the ground (black wire) from the battery. Be careful to put the cable away from the battery terminal.
Step 1: Undo the panels to the left and right of the steering column.
a. Put on your parking break. You'll want to prevent the car from moving because you will soon put the car in gear.
b. Put your keys and turn to the starting position (but don't try to start the car). This allows the gear lever to move.
c. Move the gear shift to lowest gear. This puts the gear shift lever to a place nearly out of the way of the panel so that you can pry it out.
d. Using bare hands, pull smartly on the plastic edge closest to the steering wheel. Pry out the panels by hand as they are both held by tabs. This is hardest to do the first time. Keep in mind that these are pieces of plastic, so be careful. Once panels are out, let them dangle. You only need access to the instrument panel screws.
Step 2: Remove the panel that encloses the instrument cluster.
e. Remove the 8 screws that keep the instrument cluster panel in place.
o Two on left of steering wheel
o Two on top of instrument cluster (upside-down)
o Four on right side of steering wheel
f. Wiggle/pry out the instrument cluster panel. Be careful as the center is held in stronger than the sides. In addition to screws, there are different tabs that assist in holding this in place.
g. Before removing the instrument cluster panel, disconnect the clock and emergency light electrical connectors. While the clock connector disconnects easily, the emergency light has a locking tab that needs to be pushed in to disconnect. I used a small screwdriver to push in the tab to get the connector to disconnect.
h. Remove the instrument panel. Turn it over and locate the clock's protective cover.
i. Open the clock's protective cover by loosening the tabs. Be very gentle to these tabs.
j. Once the cover is removed locate the light bulb.
Step 3: Replace the light bulb located on the back of the panel (removed in step 2).
k. Unscrew the light bulb and remove.
l. Install the new light bulb. Check the light bulb before you install it. Be careful when rotating the new light bulb. in place. I've read in other posts that the light bulbs are VERY sensitive. I used a small screwdriver with plastic on the head to screw the light bulb. in.
m. Replace the clock's protective cover.
o. Reconnect the clock and emergency light's electrical connectors.
Step 4. Reinstall the instrument panel (removed in step 2).
p. Fit the instrument cluster panel back into it's original position. Be careful with the fan vents. I suggest aligning the fan vents first, then fitting the panel.
q. Screw in the 8 screws that keep the instrument cluster panel in place.
Step 5. Reinstall the panels on the left and right of the steering column.
r. Push both panels back into place.
s. Move the gear shift lever back to park.
t. Remove the car key.
u. [Optional - disengage the parking brake]
LAST - Reconnect the battery.
TEST - Reinsert your keys and turn them to the starting position (but don't start the car). The clock light should light up.
Note: Because the power has been reset, you will need to enter the factory stereo code and reset your radio stations.
May 25, 2011 | 2004 Honda Odyssey
4 beeps but won't come on
4 beeps of equal lenght suggest that system timer is not working, you need to change cmos battery on your laptop. If you are game, that is how you change CMOS battery on your laptop:
1. Switch off computer, remove power cord and battery, turn computer "proper" side up, open and press power button to discharge
2. Open display in full (180 degree), there is small indent on hinge cover, close to hinge on right and left side, slide in little flat (screwdriver will do) and lift right side up, slide cover towards left and remove it, do not lift on both sides simultaneously!
3. Remove two small screws on the top of keyboard, lift keyboard slightly up and towards you, be aware that keys and tabs on keyboard are fragile and difficult to replace! Lift keyboard connector and slide the cable out. it is not really necessary to remove keyboard, but it easy to replace without keyboard being in the way.
4. Find coin battery, disconnect cable from socket by pulling it gently towards the battery. Remove cable from guides and battery from it's seat
5. Replace battery with exact same type, put it back into it's seat, guide wire through and connect it back to the board.
6. Re-connect keyboard cable, place front keyboard tabs into palm rest and screw back two back holding screws
7. slide in left side of hinge cover into place, press from left to right till it click in place.
8. Re-install battery and power cord, switch on computer, re-programe BIOS ito previous state.
This should solve your CMOS batery problem. Of course you can send your laptop to the technician but that will be no fun at all... ;-)
Aug 07, 2010 | Dell Inspiron B130 Notebook
My toshiba laptop won't turn on!
Place the battery back in and the power cord. Follow the power cord all the way to the plug and verify nothing was unplugged by accident. (the box on the plug sometimes disconnects without the user knowing it) This could have caused your lack of power. Hope this helps.
May 09, 2009 | Computers & Internet
I can't find the cmos battery in my Acer TravelMate 512DX
you have got an older model, try this:
follow the instructions:
you will need:
a slim x-screw-driver
a sharp knife with a slim blade and
a cup or else for the screws, don't loose them!
a new c-mos bios battery model: CR-1220 (exchange it while your in there!)
you find c-mos battery and hdd under the keyboard!
- turn off the power, remove accu and charger cable, for static electricity is friendly fire
to your laptop now !
- open your screen to max. fold (angle of 180 degrees)
- look for removable plastic part near to left holder of screen
- carefully remove it
- also remove plastic panel right to it in the section between display holders
metal should be visible now
- carefully! remove keyboard, starting at the left side, continuing topside
as you won't be able to fully remove it, simply turn it over
- unscrew any screws holding the metal plate, remove it
- now you see: left the CPU plus cooler, top right middle the hdd still in an adapter attached
to the mainboard, at it's lower right the C-MOS battery (g
- turn loos these screws
- carefully remove the frame/adaptor holding the hdd
- unscrew again the adaptor
- seperate hd fram adaptor
... and gotcha!
be careful to get a proper notebook hd (samsung or such)
exchange CMOS-battery by chance
reattach new hd to frame, again carefully!
to reassamble: rewind the procedures
put everything back in place
replug, pray and turn on the lappie.
wish you luck.....
Jan 19, 2009 | Acer TravelMate 512DX Notebook
I have a 1988 bmw 735I it was sitting for about a month and had b
Sounds like you left it too long without starting in the first place.
It's possible that you had just enough juice in the battery for the one start. Even leaving it run for a while might not put enough of a charge back to start again.
If it was a very cold night or several cold days then most of the battery could have discharged. Release the battery terminals & put some vasiline or petrolium jelly on the contacts then re-attach the terminals. This should help prevent further discharging.
Either the battery is old & in need of reconditioning or replacement or you may have a leak somewhere. Sometimes alarms can draw a lot of power from a battery if left too long.
Try another battery or see will it start no problem with a pair of jump leads attached to a car or truck.
This should tell you very quickly.
Dec 10, 2008 | 1988 BMW 7 Series
Sony ericsson t303, how do i open the back cover to put in my simcard?
To insert the simcard and battery:
1.Remove the battery cover by sliding it outward from your phone
Slide the SIM card into its holder with the contacts facing down.
2. Insert the battery with the label side up and the connectors facing each other. Then replace the battery cover by sliding it back, now inwards.
Note: Do not force the battery cover to its place. Slide the battery cover carefully onto the phone and close it.
For the online manual of your phone, check out the URL below:
http://www.sonyericsson.com/cws/download/1/497/033/1216462727/T303__UG_EN_1210_1909_1.pdf
Oct 14, 2008 | Sony Ericsson Cell Phones
Lands Phones Logo
324 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
