Question about HP PSC 1350 All-In-One Thermal Printer
HP1350 Watercolour paper
Hullo
Can the HP1350 handle watercolour paper and, if so, how does one set up this type of printjob?
Thank you.
Fi
Drummonds Cove
Western Australia
    Problem Solver:
  • 20 Answers
Sir ,
your printer is a psc hp1350 ink jet printer . you can only use the the inkjet paper for your printer. If your paper is 8.5x 11 inkjet compatible you can use that to your printer
yours,
alecz
Posted on Apr 25, 2008
Paper jam at exit
Have you set the tray to thick cardstock in the printer?
If not try that. This will let thicker paper go through more easily.
Make sure you bot have the tray as the printjob set up as the same type of paper.
How much does the paper weigh?
Also try printing from the manual feed. You're paper path is shorter that way and easier for the printer to handle.
Does it only jam on this type of paper?
Might be a fuser easy but don't think that's the case with this one.
Apr 01, 2014 | Xerox Phaser 6125 Laser Printer
Fibres appear on canvas after painting
it is pretty obvious that you did not prepared canvas correctly, before you use your medium you need to prepare it. use gesso to even the surface of the canvas seem like you are using water based paint on natural fibers.
fibres in the canvas are picking out the water, swell and raise from the surface,
easiest way to fix this problem is to stretch well your canvas, then use flat knife or broad spatula and evenly work gesso into the working surface, wait day or two and repeat the exercise, sometime even more than twice, if you are doing showpiece which will be covered with high gloss finish, apply at least three to four layers of gesso sanding with 600grit block between layers, your artpiece will then really shine.
if you work on paper, use good quality aquarell (watercolour) or similar paper, stretch it well, pre-wash and they use your airbrush tints or paints. gesso or fixative can be used as well on paper.
if you paint on wood, you definitely need two layers of gesso, if this is very light wood - probably even more, oak and dense woods, especially well seasoned (i tend to buy wood from demolition sites and then make my own as i need) are best for the purpose, do not use planks thinner than 10mm (3/8"), my preferred is actually 20mm (3/4").
if you have any other question - feel free to ask, do not forget to rate... :-)
Jan 30, 2014 | Airbrush-Depot Master Airbrush Model G23...
Poor print quality
if cartridge and drum did not solved this problem, this meant that problem lies with mirror or tracking system and repair that bits is usually beyond home user.
firstly try to check and clean all rollers and traction system, work from tray catcher up, follow paper trail and check for stuck hair, bit of paper or any other debries, clean all rollers. then follow paper procedure below:
as this is easy, create a page of white and black about 10mm lines and then print full page on 120g watercolour paper (this is bit grainy paper which will work as "scrub" of the system), this will remove if any, debris from transfer drum in most cases.
if these solution do not work, if you game, remove back, mark all wires where they go, then remove motherboard panel, mark mirror position, clean it up and this will solve the greyness problem, or kill the printer totally...
Jul 20, 2010 | Brother HL 5250DN Laser Printer
Hullo, i have a canon ir3300 that am trying to print with but it has failed how do i do it
Did you try to print test page from driver properties on PC? Did it came out OK? If yes then you have problems with document that you are trying to print.
Also it can be that you have wrong paper size set in cassete or in printer drivers.
Please be specific, how does print fails?
Jul 12, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Colour laserjet HP cp2025 keeps going into cleaning mode - why ?
Re: CP2025 cleaning at every possible moment Talked to HP support and fixed mine by changing Settings/Paper Handling/Tray 2 Type to "Heavy 111-130g"
All paper handling settings as follows:
Default Paper Size: Letter
Default Paper Type: Plain
Manual Feed: Off Duplex: Off Bind: Long Edge
Tray 1 Size: Any size Tray 1 Type: Any Type Tray 2 Size: Letter Tray 2 Type: Heavy 111-130g
Paper Out Handling
Specify Time and Action Paper Out Time: 0 Seconds
Paper Out Action:
Override
Apr 17, 2010 | HP Color LaserJet 2600n Printer
I have a watercolour painting that has ''cockled'' can I paste this onto Board, or Iron ?
I went directly to the Paper Makers, and expect their answer soon . I do not want to incur expense with yourselves, so cancel my query Thanks D.G.
Sep 17, 2009 | Computers & Internet
Disable copier function
Hi nath_sabari: Try this info. System settings The HP ToolboxFX System Settings tab contains links to the following main pages: ● Device information. Change the device information settings for the all-in-one. ● Paper handling. Change the all-in-one paper-handling settings, such as default paper size and default paper type. ● Print quality. Change the all-in-one print-quality settings. ● Paper types. Change the all-in-one mode settings for a each media type, such as letterhead, prepunched, or glossy paper. ● System setup. Change the all-in-one system settings, such as all-in-one language and jam recovery. ● Service. Gain access to the cleaning mode procedure for the all-in-one. ● Device polling. Change the all-in-one polling settings, which determine how often HP ToolboxFX collects data from the all-in-one. ● Save/restore settings. Save the current settings for the all-in-one to a file on your computer. Use this file to load the same settings onto another all-in-one or to restore these settings to this all-inone at a later time. Device information The HP ToolboxFX Device information page stores data about the all-in-one for future reference. The information that you type in these fields appears on the configuration page. You can type any character in each of these fields. NOTE You must click Apply before your changes take effect. Paper handling Use the HP ToolboxFX paper-handling options to configure your default settings. These are the same options that are available on the Paper handling and Printing menus on the control-panel. You must set the asset number. The asset number is not set at the factory. This number is stored in the all-in-one for identification purposes. Three options are available for handling print jobs when the product is out of media: ● Select Wait for paper to be loaded. ● Select Cancel from the Paper out action drop-down list to cancel the print job. (Open the System setup menu, and select Paper setup submenu.) NOTE You must click Apply before your changes take effect. Hope this helps.
Jun 10, 2009 | HP LaserJet 3055 All-In-One Printer
My printer 2600n is printer continious pages....
You can restore the printer as factory setting by pressing Left & Right button & restart the printer. Then again configure the printer may be it will work.
Thanks
Sep 08, 2008 | HP Color LaserJet 2600n Printer
Password settings
hullo
open up you Linksys user inaterface click on the wireless tab then security then go to the field called WPA SHARED KEY
then type your password to secure you wireless connection. Dont forget to save the settings.
Best of Luck.
Jul 01, 2008 | Dynamode RADSLC4WG Wireless Router...
HP PSC 1350 All-In-One Thermal Printer Logo
Seeker5211
Seeker5211
