How do I recieve a fax from memory state
Instructions on diplay recomend new black cartridge, I have refilled the cartridge and I can make make a copy, in copy mode, but in fax mode I cannot retrive a fax out of memory.
Please could you assist.
Thank you Alex Wowk
in order your fax to print you need to replace the cartridge when the cartridge is low it stops printing incomming faxes and keep it in mem untill you replace it with a new one unfortunly this cartridge can not be refilled and use it Hp is better on this
Replacing the Print Cartridge 1 Open the front cover, and then open the top cover by pressing the blue levers on both sides of the top cover. 2 Remove the old print cartridge containing the used ribbon and dispose of it. 3 Remove the plastic stopper from the new print cartridge. Note You can reuse the print cartridge until it breaks. If you purchased refill ribbons, follow the instructions that came with them. 4 Turn the black spool on the right clockwise to tighten the ribbon as shown. 5 Install the new print cartridge by inserting the recessed first, and then placing the cartridge into its four holders. 6 Press down on both sides of the top cover to close it securely. 7 Close the front cover. Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada). Vertical Black Lines When Receiving The sender's scanner may be dirty. Ask the sender to make a copy to see if the problem is with the sending machine. Try receiving from another fax machine. If the problem continues, call Brother Customer Service at 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada). You can save money by purchasing the 2-PK Refill Ribbon Rolls (PC302RF). Installation instructions will be included. If you handle the print cartridge (frame) carefully, you can reuse it until it breaks.
I cannot recieve a fax from memory, I have refilled B cartridge, Window display recomends new cartridge, I can make a copy in copy mode, this tells me cartridge is OK. my machine is a Canon
MX310
If you don't use the printer often it is possible that the ink gets dried inside the cartridge, hence you get the print out with low quality or blurred. We suggest you to use original HP cartridges and keep using the cartridges frequently.
Thank you for using Fixya.
Canon cartridges have an intelligent chipset to prevent them from being refilled. To have them working properly you need to reset the chipset. Try the software on this link. If the above did not work you will need to use a cartridge chip resetter if you want to refill your cartridge.
It sound like your machine is receiving but as soon as it tries to prints the fax it has this problem.
Rewind the ink ribbon so it is nice and tight in the housing. Clean the black roller above it with some cleaning alcohol or equivalent (nothing too harsh).
See how that goes if you are still having problems replace the whole cartridge (not the refills) PC-401.
