After playing sometime the surface get hotter and stop
  • 49 Answers
THIS IS MOTHER BOARD PROBLEM. FIRST CHECK ALL SMPS VOLTS 12V,5V,24V,.FIX COMPUTER COOLING FAN (12VDC) TOP OF THE SYSTEM IC.IF THE PROBLEM IS REPEAT FINALY CHANGE MOTHERBOARD.
Posted on Aug 02, 2010
My p8 lite gets very hot when playing games is this normal
Yes it is very common these days for a phone to get hot when playing games.
how hot it gets all depends on how thin your phone is and the game your playing (Meaning the more detailed the game the better the chance of it being hotter than other games).
What I normally do is if I have a phone cover on I take it off and depending on the type of game I will try to lay the phone on a flat surface so that some of the heat can transfer.
Hope this helps.
Jun 07, 2016 | Video Game Consoles & Games
Have 2155 cub cadet when it gets hot spudders then dies wouldn't start until cools acts like it not getting gas what could be the problemn?
To be quite honest it sounds more like a fire issue than fuel. More times than not when a coil starts going bad the hotter it gets the weaker it gets and sometimes stops firing at all until cooling down, occasionally a plug will do this aswell, but I think your coil is going out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Aug 21, 2014 | Cub Cadet Garden
Phone was placed on it while playing music and now its not responding. no lights nothing, just the tablet itself getting hotter and hotter.
you might have to reset it, and give it a day's rest and then continue. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Apr 02, 2014 | RCA Tablets & eReaders
HEAT BUILD UP ON REAR TYRE OF MY 2013 ELECTRA GLIDE
tyres get hot from working on a hot road surface so if properly inflated the tyre temperature will be around 10 degrees hotter than the road surface . To get noticeable hotter means they are under inflated and the side walls are flexing excessively or they are overloaded which causes the side walls to flex excessively as well. If you are concerned and the tyre pressure is correct for the weight and speed you are travelling there are places that will inflate your tyres with nitrogen which reduces the tyre temperature considerably and extend tyre life.. Many heavy haulage trucks run nitrogen filled tyres and extend tyre life by up to 20%
Sep 04, 2013 | Harley Davidson Motorcycles
Is sharp non-cfc refrigerator power saving?
Checked any gas leaked from compressor.
Oct 27, 2012 | Sharp Refrigerators
I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
see this causes and proceed for fix it. God bless you
Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Oct 02, 2012 | Neff Cooktops
3 red lights on xbox 360 tryed rebooting, unpugging everything and rebooting, also lying down and rebooting, taking fan off and rebooting still nothing happening . . .please help it was working 6 hours ago...
Unfortunately the Xbox 360 will need to be professionally repaired.
These red light errors usually happen with little warning. Sometimes you may see strange colors or it will start to freeze, however often times it strikes without warning.
The main cause of the red light errors is overheating. In the future try to keep the console in a well ventilated area and always play with the console standing upright rather than laying flat. When the Xbox 360 lays flat the entire bottom surface area gets very little air flow, causing the console to run much hotter than if it is upright.
If your warranty is up or you just don't feel like dealing with Microsoft; the company I work for GATpro Repairs offers a flat rate repair service. We even pay for return shipping. Let me know if you have any further questions.
Good Luck!
Hank GATpro Technician
Jun 15, 2010 | Microsoft Xbox 360 Console
I have problem with my HP 6730s. It is very hot when i`m playing on it. And i have a gane witch is frameing. It is because the laptop is so hot?
Yes it is. The heat build up affects lots of parts in there, the video, hard drive, and of course the processor.
Laptops typically run much hotter than desktops for obvious reasons; there is not much room in there for equipment and fans. You may want to check into a docking tray for your laptop to sit on. Many have up to six fans situated to draw as much heat as possible out of the laptop interior.They aren't very expensive, and do make a difference. Don't play with your laptop in your lap - always play with it on a flat surface so that air can circulate under it.
Sirwriter
Nov 11, 2009 | HP (344872-001) Laptop Cooler, Cooling Fan
The touchpad gets very hot after about 30minutes use the touchpad gets hotter and hotter
may be its placed on a surface without proer ventilation. it should not be placed on bed,carpet and lap as the heat cant dissipate under such circumstances. try to get a ventilation pad for the aptop. it might help u. good luck!
Oct 14, 2009 | Acer TravelMate 5520 Notebook
Noise from the front
Car will pull if brake is binding...as soon as your speed cannot overcome the amount of braking being applied. Be careful when examining it the rotor will be much hotter than normal. (sometimes will turn blue and warp as well)
Sep 19, 2009 | 2001 Pontiac Grand Am SE
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
