Question about Zyxel Prestige 841C (P841C)
How to reset zyxel prestige 841c to default IP. I don't see reset button on the pair. please reply jafri@airblue.com
  • 85 Answers
Press the power button and hold down for 2-4 seconds that will prompt it to restart.it does not have a remote management page so becareful
Posted on Apr 25, 2008
Recently, I bought ZyXEL Prestige 660HW-T1 router, it works fine, but sometimes GREEN Power (PWR/SYS) light changes to ORANGE color and lights for a few seconds and change backs to Green. Is it Ok? or...
You need to reset your router to defaults then configure it again then it will work fine.
For that press RESET button for 10 seconds it is in back side of router.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 02, 2010 | Zyxel Prestige 660HW Wireless Router...
I cant log in to my zyxel!(zyxel ies 1248) cos of someone change the IP address so how can i reset default?
See the attached manual and look up page 42 where is shows how to reset your router to the default settings. The default ip is 192.168.1.1.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
Feb 05, 2010 | Zyxel Prestige 660R Router (P660R)
No encuentro el CD de instalación de ZYXEL Prestige 600 y debo volver a instalar. Les agradecería me faciliten los drivers. Gracias
Se puede cunfiguar el router sin el cd, para ello debes tipear la direccion the IP del router, la original es 192.168.1.1 el password deberia ser 1234, a menos que lo hayas cambiado.
Espero que esto te ayude, y por favor no te olvides the dejar calificacion.
Gracias.
Type the router's IP address in your browser address bar and hit the Enter key. The default IP is 192.168.1.1
Default password should be 1234.
Jan 06, 2010 | Zyxel Prestige 600WH Wireless Router...
Cannot connect it to Linksys wireless router.
try setting it up for DHCP and let it obtain its on IP address from the router.
May 29, 2009 | Zyxel Prestige 660M (P-660M-61)...
Zyxel P 660HW T1 how to apply DMZ mode for a CCTV
Network - NAT - Port Forwarding - Default Server, Put the IP of your CCTV Hardware/PC
This IP will accept connection on all ports.
I never did this yet so any success please reply.
Mar 26, 2009 | Zyxel Prestige 660HW Wireless Router...
I wish to restore the factory settings for my Zyxel router
You may call on 1-800-585-2494 toll free for support on zyxel support.
Dec 31, 2008 | Zyxel Prestige 334 Router
Zyxel p660r
connect a computer to the router, open your IE then type http://192.168.1.1 this is the default IP address of the router, it you have changed it, use that ip address. if you cannot locate the router IP, type IPCONFIG in your command prompt and you "default gateway" is the router IP address
Aug 10, 2008 | Zyxel Prestige 660R Router (P660R)
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Zyxel prestige 660hw wireless router
Try using the password 1234.
If this fails look for a small hole in the unit, normally marked reset. Unit must be powered, press and hold the reset button for about 3-5 seconds, then release. Note:a tool may be required to reach the recessed button.
Then try the default login and password again.
Jan 04, 2008 | Zyxel Prestige 660H Router
Did you buy this device used or get it second hand from a friend?
Nov 29, 2007 | Zyxel Prestige 660R Router (91004397002)
Zyxel Prestige 841C (P841C) Logo
291 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
