Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Hi There, the quality of wash on my Bosch dishwasher has reduced (especially on top shelf) to a point where it is almost not worth using. filters etc are clean and no issues with water enttering the machine. i am assuming it is the power of the spray which has reduced , what can i do? many thanks, Mark C
  • 4 Answers
All the jets must be clean especially the drive jets at the ends of the wash arms, these drive the arms around thus allowing jets of water to reach every piece of crockery.
Posted on Aug 09, 2010
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
Top arm stopped rotating on Bosch clasixx
not worth fixing, you are better off putting that money towards a new one. unless you can find the arm and repair it yourself
Nov 10, 2011 | Bosch 24 in. SGS43C12 Classixx...
My glasses come out looking very cloudy this has only just happened, I have cleaned out the machine, addded salt etc don't know what else to try, I have had to chuck out all my glasses. |Help it only...
Most dishwashers use an extention pipe from the lower unit that cleans the tops of the lower shelf and the bottom of the upper shelf. Sometimes, the extention pipe is not extended when it should be either because of damage or maybe soap build up. Check to be sure that the extention is free to extend. If it is resistant, a little vegetable oil on it and moving it up and down sometimes will clear up the problem. If not replace the extention.
Jun 29, 2011 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Does my Bosch SHU3032UC have a heat booster?
The dishwasher has a built in instantaneous water heater, so even if the water feeding the d/w is cold the machine will heat it the the temp required for the cycle you have choosen. Reducing the temp will not effect the wash quality at all, in fact having a lower temp or cold water filling the machine will make the drying cycle at the end of the program more effective.
Hope this helps, please leave feedback.
Jul 27, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
There is so much debris left on the dishes after the dishwasher has run, it's almost not worth running it. The debris is mostly small hard bits on the inside of glasses from the top shelf. Is this a...
this is a maintenance problem.. if the bits look like grains of sand it is actually food particles that breaks down during the cycle spraying the cups and glasses (usually the top shelf that gets hit worst). solution is to run a dishwasher cleaner through the system on a hot wash. To remove and wash bottom filters and spray arm jets. Lastly when loading the DW make sure excess food are scraped/rinsed off ...you will get better results. Thanks
Jun 22, 2010 | GE Dishwashers
Terrible smell from the washer. This is a new
do not use baking soda this will react with your detergent and leave smelly deposits and reduce the wash performance modern good quality detergents contain everything needed for a good wash result and a sweet smelling machine. try a hot wash with detergent and an empty load to get rid of smell.
Nov 07, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Diswasher doesnt clean and leaves "gunk" on top shelf items
The rinse agent is a separate product. I use CascadeCrystal Clear in a 16 ounce bottle. In your machine (if it's anything like mine) there should be what looks like a screw cap next to the soap dispenser. Unscrew that and pour in the product.I was told by the appliance store where I bought my machine that you have to use this in stainless steel washers. Also I would try a liquid type soap. I use Cascade with shine shield. I think from past experience that the pellets aren't very good especially if you have hard water.
Dec 16, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Apr 15, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My Bosch Dishwasher doesn't clean
open the door while in the wash cycle and check water is spraying from the spray arms and that the spray arms are rotating. get back to me with the results and i'll try to give some guidance
May 04, 2007 | Bosch 24 in. SGI43E05GB Built-in...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
136 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
