Question about HP iPAQ hw6515 Pocket PC
Phone completely dead
Did buying a new battery work? If so please tell me where to get onw
I had this issue and HP replaced the motherboard under warranty - but very efficiently!
Posted on May 23, 2008
My phone is completly charged and when i pull it off charge about half an hour after depending on how much i use it, it turns itself off and then when i try turning it back on the Lg start up comes on then...
The happy news is there is no problem with phone,the hardware of your phone is in good condition.The problem is the battery.The battery of the phone is dead.This a step behind Stone dead stage.Next state of your battery is stone dead.You can't even use it more.Now the phone Battery will act like charging.Your battery can take small amount charge only because it is dead..Even though you charge your battery for 2 days continuously it will stay for 30 min or 10 min depending the charge usage.
Solution for this is you have to replace it soon..Go to nearest shop and check this with their battery and buy it.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | LG KU990 Viewty
Blackberry storm battery won't charge and device won't turn on.
Hi! My phone had exactly the same problem a few days ago! I got a new battery - it worked fine for a couple of days and here we go again... It is dead! Please let me know what you did with your phone! I have a new BB curve! Thank you!
Jul 14, 2010 | RIM BlackBerry Pearl 8100
Nokia 3230 no display and keypaid laight
hello it sounds like your phone is faulty, or the battery is dead or possibly the charger is not working.
first connect the phone to a charger and turn it on, try with and without battery, if the phone does not react, either the charger is not working or your phone is faulty. take it to a repairer or buy a new one.
Jun 14, 2010 | Nokia 3230
Completely dead. new battery won't work. need to retreive info
Probably the firmware of the mobile is corrupt better that you take it to a Palm sevice centre and get it repaired.
There would be a loss of data if the firmware is changed.
Apr 20, 2010 | Palm Treo 650 Handheld
I dropped my Samsung Blackjack II (model SGH-1617)in water. I took batter out and let dry. It seems totally dead. Any suggestions?
You can try to put the charger into the phone (leave the battery out) and see whether it wants to start.
If it works, it means your battery is broken, but your phone itself still works. Then, you have to buy a new battery.
Jun 22, 2009 | Samsung Blackjack SGH-I607 Smartphone
Phone wont turn on
How long did you have the phone before this problem? Is there a warranty on the phone? Did you buy it brand new?
Feb 15, 2009 | HTC G1
Phone dead
Sometimes, when the battery is completely depleted, the usb or auto charger will not charge the battery back up. Be sure to use the Wall Charger that came with the phone. Give it some time to recover, as this usually works. If not, then you might need to replace your battery.
Aug 29, 2008 | Motorola Mobility ROKR E6 Smartphone
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
Battery won t charge or operate phone Problem - T-Mobile MDA Compact Smartphone
Okay, I searched and searched until I found a solution that worked for me. I tried the USB thing, I got my phone to turn on once, but never to charge. Here's what I did:
(Do this at your own risk)
I zapped my battery with a 9v battery. One wire on each terminal and then held it to the MDA battery (positive to positive, negative to negative) for about three seconds. I did this about five times. (Don't let the wires touch while they are connected to the 9v battery.) I IMMEDIATELY plugged my phone into a wall charger, NOT my computer (The computer wouldn't charge my phone). As soon as it was connected to the wall charger, I turned it on. After starting up, the orange light came on, and it started charging. I was skeptical about this solution at first, but trying everything else I resolved to do this and then if it didn't work buy a new battery, but it worked and my MDA is charging as I'm typing. The original ideal came from a post on the xda-developers website by dew1989. I added the additional steps that got my battery charging again. I hope this helps!
Dec 04, 2007 | T-Mobile MDA Compact Smartphone
My phone dosent turn on or nothinq
When the battery is totally depleted, you will need to use a charger that came with the phone. Sometimes it will take a few mintues (give it 10) for the battery/charging circuit to come on.
Sometimes you can charge from other sources than the charger that came with the phone. You generally will need enough charge on the battery to start the phone.
Example: If I have enough battery to where the boots and turns off, I can generally get it to charge from USB or my car adapter. You will need to get the phone to turn on and boot most of the way up before it will take a low current charge. If my phone is so dead it will not even turn on, I must plug it into the AC adapter. Sometimes even then the light does not turn on right away.
The problem is probably due to the number of amps provided by the charger. When the battery is totally dead, the charging circuit is drawing so many amps that it will prevent low amp chargers from being able to do the job. That's why these phones have such heavy duty AC adapters.
Apr 28, 2006 | T-Mobile Sidekick II
HP iPAQ hw6515 Pocket PC Logo
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
