Remote not working,i am using new batterys also if you use your mobile phone camera to check the remote no signal.
  • 49 Answers
CHANGE THE CRYSTEL AND REMOTE LED THEN IT IS DEFINITALY WORKING.
Posted on Aug 02, 2010
LG tv remote control not working
change crystal on the remote.........to check if remote is ok use ur camera mobile......how--
1. switch on your mobile phone camera.
2. Set mobile so that you see the bulb(LED) of remote on your mobile screen thru mobile camera
3. Now press any button on remote (ensure batteries are installed in remote)
4. If u see a purple light comming out of the remote bulb(LED) then remote is ok......change remote sensor ( also called eye) of your TV
Mar 28, 2013 | LG Televison & Video
Our Samsung remote control ARH-428 will not work. We have changed batteries however we can not make it operate our air-conditioner
If even with new batteries not working means transmission signal problem. May be with remote or receiving signal problem with indoor. Check your remote with camera mobile and press on/off switch. If it's ultra light flashes, it's o.k. Then repair receiving signal in PCB.If no ultra light in remote, replace remote.
Dec 27, 2010 | Heating & Cooling
Remote was working fine.all of a sudden it stopped working.I put new batteries but still don't work.What could be the problem?
First of all check if the remote is working. How do we check the remote? Use your phone camera. While watching the LED in the remote through your mobile camera, press any remote button. You should see the LED flashing. You can't see the LED flashing by naked eye but with the help of camera you can. If the remote LED transmit the signal (if it flashes) then the remote is working fine. In this case your TV has the problem. If you can't see the LED flash, then your remote is the problem.
Open up your remote and check if there is dry or broken connection, or short connection.
Aug 31, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Tv not taking remote signal
First check if the remote works. This can be done by using a digital camera or cell phone camera. Point the remote at the camera lens and start pressing buttons on the remote. If you see a blinking light on the LCD preview screen of the camera, then you know the remote is transmitting.
If the remote is not transmitting, replace the batteries. If this still does not work, you should get a new remote.
If the remote is properly transmitting, then the issue is going to be with the TV. It depends on the type of TV you have but usually is either the IR sensor board or the main board which are in charge of receiving and decoding the signal from the remote.
Oct 13, 2009 | Televison & Video
Stopped working. replaced batteries and still
well 1st of all try to check if there is any corrosion on ur remote terminals if there is not try to check the voltage of each baterry also check if there is any corrosion but if not try to install the baterries back again and bring any mobile phone then try to see the video of the outout signal from the remote when u press and hold on any button on the remote at the same time u must direct the remote closely to the mobile phne camera so if u see the light of the IR LED then the remote works but the problem is from ur IR receiver on the device but if the IR LED is not blinking then u must dissassemble the remote and change the IR LED with new one or u must change the ceramic crystal
Jun 29, 2009 | Bose Televison & Video
Hunter Remote 85094-1 doesn't work after I dropped it
Try these simple trick to find out yor remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
otherwise, the problem with the Remote sensor or related components of the device
Jan 06, 2009 | Hunter 52" Ceiling Fan With Light And...
New flatscreen/remote not working
If your Remote is ok, then the problem with the Remote sensor or related components of the device.
Oct 16, 2008 | RCA DIRECTV Satellite Remote Control
Remote ontrol stopped working !
otherwise, the problem with the Remote sensor or related components of the DVD.
Jan 07, 2008 | Denon DVD-1000
Remote control failure
Feb 06, 2007 | Kenwood VR-409 Receiver
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
