Question about Nintendo Wii Console
Red led light is on but ant switch it on
Red led light is on but cant switch it on
  • 61 Answers
Your wii probably go shut of with out it meaning to like a power outage... try unplugging you wii for around an hour then plugging it back in
Posted on Aug 04, 2010
  • carmenleong Aug 04, 2010
    Thanks for the solution but i have tried it and it still wont switch on. The red LED lights stays on but nothing else.
  • Mathue Aug 04, 2010
    you might have an internal problem... try taking your wii into bestbuy for geeksquad.. and could you please give me four thumbs up im trying to earn a good rank
My television can't switch on
have you tried turning the tv off for 4 to 5 hours unplugging it
Jan 13, 2014 | LG 47LM6200 - 47" Class LED 3D Cinema HDTV...
Hi i have an experia ant the littli led light on the top stays on red all the time
Hi.
The little red light means your battery requires charging.
Plug in the charger and allow it to charge.
It should change colour to orange when it has over 15% charge in it and then turns green when it is 90% charged.
If it still stays red dispite being fully charged. Try removing the battery for a few seconds and then replace it again.
I hope this helps.
If your phone is fully charged and it still has a red light, then take it back to the shop you acquired it and get a replacement.
It means you have a hardware fault.
Mar 09, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Have 01 harley wideglide. have placed 4 led lights with 6 lights per light each light has 1- 2 connectorwire red&black, tied al reds together, same for blacks. i can put reds straight to 12vdc,and...
You have to wire your switch in series with the lights. First, to make it simplier, use a two-pronged single pole single throw switch. Run a red wire from the battery to one of the prongs on the swith. Run another red wire from the other prong on the switch to the red wires of the LED's, Gound the black wires from the LED's. Now, when you turn the switch on, current will flow from the battery through the switch to the LED's and on to ground. I'd also put a fuse inline between the switch and the battery.
Good Luck
Steve
Nov 16, 2010 | Harley Davidson FXDWG Dyna Wide Glide...
I can't get the KX-TGA405B Extender to fine the base on the KX-TG4033 phone? I have tried moving it to other locations in the house and outside, and all I get is the status light blinking red. The ant....
With the repeater connected to its power block plugged into an outlet, find the tiny square button on the back of the repeater. It's below the word 'Program.' (The instructions do not mention the Program button at all! ) Press the button. The two LEDs on the repeater will flash red continuously.
At the base, press the 'Locate' for five seconds and release it. Then press it briefly once. Next, press the 'Locate' button again for five seconds and then press it briefly once again.
The two LEDs should now show solid green indicating that registration was successful.
After the process has been completed, the registered repeater may be relocated to the desired area. If the lower LED remains red, you will have to find another place to put the repeater. A location where the LED is green would be best but mine worked well when it was amber.
Oct 28, 2010 | Audio Players & Recorders
When i turn on my ps3 to choose a user it doesnt show any of the users i have, so obvioulsy i cant do anything on my ps3. All it shows is the wavy background, Help me pleaseeee!
Try doing a master reset of your system.
1.) Turn off the hard switch on the back of your system and wait 30 seconds.
2.) Turn the hard switch back on so that the PS3 displays the red "stand by" light on the front LED.
3.) Hold your finger on the soft "on switch" (above the red LED) for about 10 seconds until the PS3 emits a beep.
Good Luck!
-Tom
Sep 28, 2009 | Sony Playstation 3 (PS3) Console
The ant light and the other light light up red when i key the kic
the tx/rx liight is green when your radio is recieving signals and turns red when you are sending signals. the ANT light is red when your SWR is too high (over 3)
1. turn the knob labeled swr cal all the way counter clockwise
2. set the rf swr cal switch to the CAL position
3 key up the mic and hold it while you rotate the swr cal knob until the needle reaches the swr cal postition
4. set the swr cal rf switch to the swr position
5. key up the mic while on chanel one (record the the number)
6. switch to chanel 40 key up the mic (record the number)
if the number on chanel one is lower than the number on chanel 40 then your antenna is too long.
Sep 14, 2009 | Cobra 29 LTD CB Radio
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
May 21, 2009 | Sony KV-29FX30 29" TV
Cant get the red led light green again
Disconnect all input and output cables and check. If the light stays red, it suggests an internal error. If not, proceed by first connecting the Sub wires and checking, then the input RCA's and checking. Remember to switch off the system before connecting/disconnecting, I suggest also removing fuses during this process.
Mar 11, 2007 | Pioneer GM-232 Car Audio Amplifier
Nintendo Wii Console Logo
99 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
