Question about Intex 2000 GPH Salt Water Filtration Pump with Saltwater Chlorine Generator
Pump/motor is making a loud straining noise for the past week-pump is about 14mths old it is working i.e filtering and chlorinating the pool when required-its just become twice as noisy other than when i got it first it had a soft hum while doing both .why has it become louder conatantly when turned on.?
    Guru:
  • 642 Answers
I suspect the pump is packing up. Worn shaft bearings and bearing housing will become noisy and get worse over time. Contact Intex, 1-800-234-6839. If the unit is still under warrenty they will replace it for you.
Posted on Aug 02, 2010
Filter working but making noise
This is an inexpensive product put out by China Manufacturing. So sorry to say, but you probably knew this as well, it is not of high quality and was not made to last. It actually is considered a Toy.
It sounds like you need to either live with the noise or replace the pump. I would recommend that if you can find it in the budget, upgrade to a real Pool Pump. Ask your local service provider or retail pool supply store about such an upgrade. But your pump is failing.
Good Luck.
Apr 29, 2015 | Intex Krystal Clear Model 635 Pool Filter...
New polygroup 2000 gph pump is loud
firstly, don't be so certain that doubling your pumping capacity isn't damaging other parts of your pool system. Excessive flow reduces filter efficiency, can cause hyper chlorination, and cause faster degradation of the plumbing and pool surfaces.
a noisy pump typically indicates poor lubrication on bearings and bushings in the pump assembly, or misalignment of those parts. Things like this happen.
Either replace the pump (and i recommend going back to the original design specs) or rebuild it, using new bushings / bearings, high quality lubrication, and be certain that the drive shaft is perfectly straight, and that the bushings allow it to spin freely.
Jul 04, 2014 | summer escapes Polygroup Quick Set...
Pool pump makes a loud noise
bad bearings change pump and motor
May 14, 2014 | Waterway Impeller Pump 2HP SD WW
We have an Intex above ground pool that takes salt and converts to chlorine. We filled it about a month ago and all was fine for a few weeks, then in the past week the water began turning green. We have...
Intex chlorine generators are very low output generators that fail very often. There is a reason they are so cheap. They do not work well. When using a chlorine generator, it is important to test manually for salts and free available chlorine on a daily basis. Just adding salt because you have a generator will not make your pool manage itself. In order to get the most basic chemistry under control, you need to test for alkalinity, calcium, pH, and free available chlorine.
If you do not have the ability to test these things, spend $10 on a 7 in one test strip that will give you this information.
Note: Chlorine generators have more negative aspects to them than positive. There is not a cost savings as advertised with these units. It actually costs more money, and takes more time to care for. The salt is very corrosive to the pump and filter system as well as the pool itself. The long-time cost would be cheaper to run a chlorine or bromine pool.
May 02, 2011 | Intex Automatic Salt Water System for ...
I have Hayward Centurian SE 2 hp pool motor pump,around 15 years old. Just the other day it started making a loud whining noise. Is there a quick fix for this?
if its whining but still spinning, the bearings are done. If it just makes a loud noise, the capacitor could be bad or the bearings have seized.
Jul 04, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
I have a bestway 10 ft pool, filter making loud noise, doesn't seem to be working. Its only been in use for the last 2 days, tried releasing air, makes no difference.
Normally, the filter does not make any noises! The noise is generally from the pump. Since I am not sure what you have on the pool, to be able to find the issue, we will need a bit more information.
Do you have a seperate pool pump and filter? The pump will have a motor and some have a debris basket in front of the motor. If this is where the noise is coming from, you may want to return/exchange the pump if it is only two days old!! When you turn on the system, do you see water moving to the pump, air in the basket, or is the motor getting hot to the touch?
If you have a seperate filter from the pump, what is the pressure gauge reading on the top? If you have one, check it when the noise starts. If it is higher than it was when working properly, you have a blockage somewhere from the filter to the return line. If lower, then you may a small leak, generally o-rings, and will need to replace what is bad.
If the motor on the pump is making the noise, then it can either have debris in the Impeller area, or it is going bad. Hope this helps! If you can let us know what pump and flter you have, we may be able to find out what is going on.
Jul 01, 2009 | Pool & Spa
Pool filter making a loud noise
The sound you are hearing is most likely rust forming on the inside of the motor. It tends to happen when a pump seal starts to fail. Water travels up the spining shaft from behind the impeller into the motor. The high pitch is a direct result.
Solution. Replace the pump seal, and find a motor repair shop/ Pool pump repair shop to take a look at the motor. Have them check the brushes and bearings. Once clean of rust the motor should be quiet once again.
Jan 25, 2009 | Harmsco Pool and Spa Cartridge for Filter...
Intex 2000 GPH Salt Water Filtration Pump with Saltwater Chlorine Generator Logo
135 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
