Question about IBM ThinkPad A31 Notebook
Lenovo R60 "0190 critical low battery error"Given on start up.
After the masg machine shut down autometically. I change Battery pack,CMOS bat,Adaptor by new one but problem not solved . Pls Help me
    New Friend:
Cmose batterychang & your laptop ok
Posted on May 30, 2013
Pyrhyc
  • 2028 Answers
SOURCE: IBM Thinkpad T21
This is a common problem with the T20 series Thinkpad. The problem is with the power management chip. Unfortunately, you will have to replace the motherboard to fix it. Since these are a bit on the older side, you can get a motherboard off Ebay at a reasonable price.
Posted on Aug 05, 2008
  • 1116 Answers
SOURCE: 0190 critical low battery error
push the power button at the same time with thinkpad button, and fast press F1 key.
you should need to do this 3 times to fix the problem.
Posted on May 14, 2011
kamal1984
  • 1383 Answers
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 29, 2009
harvester3
  • 181 Answers
SOURCE: IBM ThinkPad T20 - 0190 Critical Low Battery - Will not boot
When you boot, do the lights come on briefly, then go off? If so, the memory may be to blame.
Also, try booting without the battery at all.
Let me know.
Thanks,
Posted on Dec 20, 2007
lights ambar blinking 5 times, stop, and again..
I was pushing the power button at the same time with thinkpad button, and fast press F1 key.
I only needed 3 times and it fixed problem.
Right now laptop remaining in bios mode, charging battery normally.
good luck!
Posted on Jul 19, 2010
0190: critical low battery error
When old IBM Think Pads fail to boot it is usually because the CMOS battery has worn out. It is very easy and inexpensive to replace. Youtube has numerous videos showing how to replace it e.g. https://www.youtube.com/watch?v=8ZI-8Q2j-zQ
Jan 24, 2018 | IBM ThinkPad A30 Notebook
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
My lenovo 3000 G410 when ia tr to start it nothing happens???? help
Is there power when you turn the system On?
In your case it is very difficult to find out which is causing the system not to power, this can be multiple devices on your ssytem.
trying to eliminate one device after another try following the steps below:
>remove the Battery from the system, unhook the adaptor as well then Press and Hold down the power button for 7-10 seconds to drain any power on your motherboard.
>after power draining the system connect the adaptor to your laptop, do not insert the battery yet, Power the system without the battery, if the system turns on leave it turned on for about a minute then shut it down normally.
>insert the battery to the laptop turn the system on if this turns on without any error then your concern is probably ok and fixed.
>but if the system still does not power up having the battery connected to the machine a device on your system can or maybe damaged either the Battery or the Motherboard having an issue with the battery conencted to the machine...
if your system is in warranty call Lenovo and have it sent to teh service center for proper checking and repairs.
Jun 29, 2010 | Lenovo 3000 Y410 Laptop
My lenovo 3000 Y 500 7761 47Q is shutting down abruptly. Hi Team, I am using Lenovo Laptop since Aug 2007. Around an year back April 2009 my laptops adapter was short circuited and I purchased a new one...
Have you tried a different battery. When the system is on, please check your battery settings to see if it is fully charged. Go to Start/Control Panel/Power Options and the very last tab.
This should tell you how much battery power is in. If it is very low it means that your battery is not getting a full charge and this could be the cause of your problem.
Let me know how it goes. Don't forget to vote for me.
Mar 24, 2010 | Lenovo IdeaPad Y510 Notebook
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Mar 05, 2010 | Microsoft Windows XP Professional With...
Ibm think pad r32 0196 critical low-battery error will boot up then turns it self of
Fail safe in the battery has engaged. See if the computer will start without the battery, using just the power supply. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery. Also change the CMOS battery inside the computer
Change the CMOS battery
Nov 04, 2009 | IBM ThinkPad T20 2647 Notebook
Critical low battery error 190
This sounds like a fail safe in the battery has engaged. See if the machine will start without the battery, on the supply only. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery.
Aug 28, 2008 | IBM ThinkPad T20 2647 Notebook
CMOS BATTERY ERROR
You said that you already bought a new cmos bat, but still theres a problem.check the cmos battery socket,power on tyour pc and go to cmos setup,optimize default setting and set time and date.
May 27, 2008 | Computers & Internet
"Critical Battery Error" even with not battery in laptop
Do you have another power supply to use?
Also, is it keeping correct time and date?
Dec 14, 2007 | IBM ThinkPad T20 2647 Notebook
IBM ThinkPad A31 Notebook Logo
2,786 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
