Question about LG LSC121PMA Split System Air Conditioner
Lg air conditioner not responding to remote control
My window lg air conditioner is not responding to remote control although remote is working properly. The display screen of remote is showing all the functions.
Therinnaiguy
  • 1420 Answers
SOURCE: LG split system air conditionsr
3 flases indicates a communication error. Have a technician check wiring and connections.
Posted on Aug 30, 2007
  • 7 Answers
SOURCE: Remote Problems
you dont leve the remote in the sun do you? could be an issue
Posted on Jan 25, 2008
bobotfel
  • 236 Answers
SOURCE: air conditioner remote
here are some icon meaning, this may help.
Posted on Apr 28, 2008
  • 4 Answers
SOURCE: I do not have the manual for my LG LS-D2461HS air conditioner
Look at
www.canbysales.com/support.htm
Servicemanuals
2005
sevicemanual LSC091PMA / LSC121PMApma
Posted on Jan 20, 2009
louislevel_2
  • 374 Answers
SOURCE: my LG air cond will only work when put on to manual ON
hi! there,
have you ever check the batteries,try to replace a new one.or if not function after replacing
try to clean the pads behind in any button of your remote.doing this open your remote there are quick lock in the side of your remote,use flat screw driver to loosen this be carefull to break the
lock,try to cleran the rubber pads by cotton buds
to remove oily debris and on circuit board if you have an eracer in pencil try to rub this gradually
until carbonize element disappear.then put back
pads and cover together and try.cheers and have a nice day don't forget to rate me thank's
Posted on Apr 04, 2009
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
Kelvinator ksr27g con manual
see the led bulb of the remote control by using a camera then switch on the remote if it blink the remote is good but if not its bad. dont forget to put an battery on it. then test the ac unit manually, if the unit start replaced your remote control.
May 30, 2013 | LG LSC121PMA Split System Air Conditioner
Remote with new batteries won't work
Even after replacing new battery cells only ON/OFF button responding and other buttons are not responding. Pl suggest how to solve it
Jul 15, 2012 | LG LSC121PMA Split System Air Conditioner
Mt timer butoon is stuck on timer so unit wont work
All LG room air conditioners should be able to be operated without using the remote, by just using the controls on the unit. Replacement remotes are available from an LG service provider.
Jun 05, 2010 | LG Electronic Window Air Conditioner
WHAT AM I DOWING ?
Check your remote controller batteries and try again if this doesn't work let me know,
May 11, 2009 | LG Heat cool Window Air Conditioner
LG Spilt A/C
medev,
there is a lot of reason why your LG split unit would not work by remote control.
first likely trouble is the remote itself. it could have drop from a height and broke the remote, or corrosion has set inside the remote if you left an old battery for a long time and it could have broken it.
secondly which is not more likely to happen is the remote receiver in your unit got broke that is why it can not communicate with your remote controller. it could happen if someone has serviced your evaporator and could have disconnected wires to the receiver , or wires were just left not connected.
you can test the remote if you have an identical unit which is working with a working remote. use the working remote to your unit then you can decide.
i hope i was able to help.
Jun 24, 2008 | LG LS-L1210CL Mini Split Air Conditioner
AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Jun 05, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
281 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
