I have a Candy Holiday 6. The cycle is done but the door won't release so I can open it. I have tried several different wash settings. What should I do?
5 Suggested Answers
SOURCE: Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Posted on Jan 04, 2010
  • 6277 Answers
SOURCE: My Candy washing machine stops
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 12, 2011
  • 273 Answers
SOURCE: i am using a candy
http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=11
Good luck from Detroit, MI, USA.
Posted on Jul 18, 2011
  • 6277 Answers
SOURCE: My stackable units washing machines
This does not sound unusual to me! Many models do not operate the unlocking until a bit of time has passed. It could be that the original set-up did not work correctly, confirmed by the fact that different but new switches do the same;-0)
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Sep 09, 2011
Balay washing machine door wont open
We were staying in a holiday apartment and couldn't get the Balay washer/dryer door open on dryer cycle. Tried all the previous solutions and none worke. my husband turned the power off to apartment at fuse box and the door clicked open after a couple of minutes.
Feb 18, 2014 | Washing Machines
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
My stackable units washing machines lid lock switch was replaced. Now it wont let you open the door for a couple minutes after the cycle is done. Then it will release the door. Tried differant switches...
John C
Sep 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
Wash cycle stops and light on the extra dirty symbol lights up
This is might be the drain filter. When the drain filter is clogged, the machine won't empty itself of water.
Candy has a troubleshooting webpage that lists many possible problems/solutions:
http://service.candy-domestic.co.uk/fault-finder/FaultFinder.aspx?Section=11
If you do try to check the filter, keep in mind that opening the drain filter will yield gallons of water on your floor, especially if your machine does not have the drain hose next to the filter opening. You'll need to have some way of transferring the water ready before opening the filter.
Good luck from Detroit, MI.
Jul 18, 2011 | Candy Washing Machines
Dec 23, 2009 | Candy Washing Machines
WASHING MACHINE DOOR WONT OPEN
Call the manufacture it will be under warranty if it's only 6 months old as the machine will have to be torn down to get to the defective switch, just the top will have to come off if your lucky.
Jun 17, 2009 | Haier Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
