Question about Canon PIXMA iP3600 Photo Printer
Erreur 6C10 imprimante canon IP 3600? - Canon PIXMA iP3600 Photo Printer
Erreur 3C10
The 3XX code -fan abnormality.
Feb 01, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Mon imprimante canon ip 6600D marque fout 6A00 foutcode
This is caused by paper jam, you have to check the printer for unnatural obstacles inside it. I will try sollution in french:
Ceci est caus? par bourrage papier, vous devez v?rifier obstacles artificiels ? l'int?rieur de l'imprimante.
I hope this will help.
Jun 04, 2011 | Canon Pixma iP6600D InkJet Photo Printer
Canon pixma ip 4840 ink aborber full reset procedue and software
how can i reset canon ip 4840 . this eror is full inke .....
Feb 17, 2011 | Office Equipment & Supplies
Les deux voyants papier et point d'exclamation clignotes sans repture. salutations
Yat-il un code d'erreur que vous avez trouv?? Le code d'erreur indique un probl?me sp?cifique de l'imprimante, s'il vous pla?t v?rifier et de nous le faire savoir, nous serons heureux de vous aider.
Pour toute assistance suppl?mentaire, s'il vous pla?t contactez le Support technique Lexmark
Jan 30, 2011 | Lexmark E232 Laser Printer
Code d erreur 5c20....l imprimante ne fonctionne plus
Pump roller sensor error or Error Code 5C20
Condition: The pump roller position cannot be detected.
Problems and Solutions:
  • Replace Purge drive system unit
visit this link for more info
http://pcmediks.blogspot.com/2010/11/canon-pixma-error-codes-and-solution.html
Dec 28, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Eror printer canon ip4600 6c10
Comment faire pour surmonter les dommages perinter canon ip 6c10 4600? S'il vous plaît guide
Dec 06, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
MON IMPRIMANTE LEXMARK T640N AFFICHE UN CODE D
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T640n, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
May 26, 2010 | Lexmark T640n Laser Printer
Canon PIXMA iP3600 Photo Printer Logo
685 people viewed this question
old marine
old marine
