Question about Gateway FPD2275W LCD Monitor
Monitor problem To whom it may concern, i have a problem with may PROVIEW CRT Monitor, when i turn it on the monitor generate sounds just like a clock, or just like switching on and off.. i try to open and checked it but i can't do the right way where i start to troubleshoot i try to hang the collector of the output transistor and i try to turn it on the sound stop. so what will i do? i need help.. i hope you i can get help to anyone concern.. thank you very much.. john
There may be a faulty ground usualy a green or yellow wire behind the flyback transformer. When the VERTICAL is out the sound also goes with it on some monitors so I imagine it would be the same for computers too, just disconect the vertical ground and wire it to another ground, hopefully a near horizontal ground or a closer vertical. That's all I know, I'm working on a projector project for my room. I have a lens over a boxed in TV. Thanks for reading my post.
Posted on Apr 28, 2008
    Problem Solver:
  • 19 Answers
The horizontal output transistor appears to be short-circuit.
the clicking noise is the SMPS power cycling as it detects a circuit fault.
the real problem here is finding out what killed the HOT, flyback transformer is the usual culprit.
Personally, i'd ditch this monitor. good quality flat screen CRTs can be had for almost nothing these days and the cost to repair this will exceed the cost of a good 2nd hand 21-22" sony/mitsubishi unit
Posted on Apr 26, 2008
Compaq p1220 crt monitor...no power dear, when the electric power generator is running and i turn on monitor it works....but on the station electricity its does'nt powers on....infact the both voltages...
Sounds like there is an issue with the power coming in or there is a problem with the internal power system have you tried any other montiors on the power generator?
Feb 28, 2011 | HP Compaq P 1220 (Carbon, Silver) 22" CRT...
On screen menu
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 18, 2008 | Proview PX-986 19" CRT Monitor
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
Proview 900w
this prob is memory is in monitor so contact sevice engg of proview
Dec 11, 2007 | Proview PL926WBi 19" LCD Monitor
Over rang
on crt monitor adjust screen referesh mde to 75Hz
or go to windows safe mod e
You can see your monitor ranges ;
right click desktop -> properties -> settings -> monitor
You'll see Screen refresh rate here
under the that there is a box "Hide modes that this monitor cannot display" click that.
Now computer shows your monitor range in list. When you select bigger value different than list , gives error " OUT OF RANGE "
Dec 03, 2007 | Proview PT 15.1" LCD Monitor
Screen goes dark
it indictes problem with ur crt tube in monitir
Dec 02, 2007 | Proview PL926WBi 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
