Question about ASUS HS1000W Wireless Headset
L.S I have a asus travelite HS-1000W wireless headset, its 8 months old, i cant find the manual, but the last couple days the headset shuts him self off, doesnt matter if i have it on the charcher or not, i do remember they talked about a batterie, but i have no clue where its at, the lights on the headset is red, but it flickers blue, and i have no idea what it means, please can you help me? thank you in advange
ziraffa
  • 827 Answers
SOURCE: My brand new Cyber Acoustics HS-600 headset microphone won't work with AIM
Hi Bob,
The first thing to check is that nothing is muted/turned down low in the Volume Control/Mixer. Then you need to go into the audio settings in AIM and select a different Microphone from the list. The one set to default is not the one you need. You'll either have a USB input/output for the headset or 2 jack plugs for input and output. These use different drivers on the computer. So just try using the different drivers from the list, one call at a time, remember to reboot AIM as you try each different one, and that the microphone volume settings are turned up in the AIM programs as well as you Volume Control/Mixer.
Hope this helps you progress
Chris (ziraffa)
Posted on Jan 12, 2009
  • 20 Answers
SOURCE: asus 1005ha netbook wont turn on
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
kapena95
Posted on Jan 03, 2010
tbreeze47
  • 3083 Answers
SOURCE: ASUS 1000WR. Have had
First order of business would be to try to get an exchange on it, since whatever is going on is not good. The problem could be a bad battery, broken wire inside the headset, faulty board connection in the headset, slightly oxidized or sprung battery contacts, a bad battery, or probably quite a few other things.
Bottom line is, you'll have to probably take it apart to check it out, and it's not going to be fun or easy.
If you can, exchange it. Otherwise, concentrate on why the battery isn't making or supplying the voltage needed.
Good luck, and hope this helps.
Posted on Nov 17, 2010
Geekman
  • 32281 Answers
SOURCE: asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Posted on Jun 18, 2012
  • 16 Answers
SOURCE: Please help me recover months of hard work saved on PC. Will not load past Windows page then re-starts its self.
What you need to do is to unplug the power cord from your system. Take out the battery. Remove the RAM's cover, take'em out properly, meaning, do not force them out, please, if you never done that before, search the internet on how to do it first. It is not that difficult to do, I promise. Once you do that, try and push the power button twice like your trying to turn it on. We both know it wont work. That's it, leave everything that way for 10 more minutes. Now put everything back. Turn on your PC and good luck.
Posted on Nov 23, 2015
Why does my headset turn on/off
Seems like what you say a power problem + the wireless band is a busy surroundig. Try some new batteries . It goes on so that's not the problem, it seems to me your signal is too weak to provide the working power and every day hours loading makes it die just faster.
May 18, 2014 | ASUS HS-W1 Wireless USB Headset
Hello, i cannot connect my headset (ASUS HS-1000W) with my playstation 3.i ve check it with my laptop and it connected.the flash light is green but not steady.i ve done all the procedure from the manual
If this is a Bluetooth headset, I have found that not all headsets play nice with the PS3. I had to switch to the Sony PS3 headset to get mine to work consistently.
Mar 09, 2011 | Video Game Consoles & Games
I have an issue using Asus HS-1000W with my wireless lan. Whenever I have a conversation or even hearing music (meaning the headset is active) my network is spiking or at best having huge latency issues....
Right, I assume you have an Android cell/mobile phone? If so take a look at the APP Google shop store for "Wifi Analyzer". This shows all the 2G or the 5G Wifi signals around you and best of all it is FREE ;-) Now you can see where all the traffic is and choose a less busy channel.
Another point to remember is to place the network Wifi hub in the open, on "show" if you understand. If you can see it the Wifi is as best as you can get.
Dec 01, 2017 | ASUS HS1000W Wireless Headset
How to connect nokia N95 to bluetooth HS-56W?
You need to pair the device first.Check if it is picked up from the other device and you may need to check its manual for a default code for pairing but that differe from devices..Hope this helps.
Oct 05, 2009 | Nokia HS-56W Wireless Headset
Where can i find genius headset hs-04u driver? the CD doesn't work anymore
pardon my grammat.. see the web at http://geniusnet.com/geniusOnline/online.portal?_nfpb=true&supportPortlet_actionOverride=%2Fportlets%2FsupportArea%2FproductCatalog%2FfindByModel&_windowLabel=supportPortlet&_pageLabel=supportPage&test=portlet-action download and exec
miy good bye,,,
Marcos Conttreras.
Mail: Marcos-C@latinmail.com
Sep 30, 2009 | Genius HS-04U Headset
Why cant i connect my dlink
Forget the D-Link drivers!!! I suffered with this same DWL-G630 issue for two years, trying different settings, reloading drivers, all with no solution. My card kept dropping it's connection, or wouldn't connect at all until I removed then replaced the card. Finally, I read on another forum this card uses the same chipset as an ASUS card, and to try the ASUS drivers. I downloaded and manually installed the drivers from here:
ftp://ftp.asus.com.tw/pub/ASUS/lan/wifi-g/wifi-g.zip
Unzip it, but DON'T run the setup.exe file, because it will try to install the ASUS program. If you open the unzipped folder you will find another folder called "Drivers". Just use your Network Settings (from your Control Panels) to manually update the driver of your DLink card, and navigate to the Drivers folder just mentioned. Reboot -- you'll probably have to reconnect to your access point/router one last time, but that's it! It's good as gold after that.
I was used to losing connections 5-8 times PER DAY (I'm 15 feet from the router!) and now I've been connected non-stop for two weeks and counting!!
Mar 20, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Blackberry 8800 headphones aren't working
The 8800 does not support the stereo function on headphones.
Here is the ATT thread: http://forums.wireless.att.com/cng/board/message?board.id=rim&thread.id=22479
Jun 06, 2008 | RIM BlackBerry 8100 HS-655 Bluetooth...
ASUS HS1000W Wireless Headset Logo
177 people viewed this question
Top ASUS Radio Communications Experts
ray gallant
Paul Chapman
Paul Chapman
Brett Duxbury
Brett Duxbury
Are you an ASUS Radio Communication Expert? Answer questions, earn points and help others
