Question about Cannon Chesterfield C60G Kitchen Range
I have a Cannon Hotplate Model SP1 and would like to replace the Pan Supports as one has broken. Can you tell me if i can replace and where pls? thankyou
2 Suggested Answers
tunde007
  • 2382 Answers
SOURCE: I have a Cannon Hotplate
Hi, this is the dimension of the Cannon Chesterfield C60G below.....
Height in cm is 90 cm Width in cm is 60 cm Depth in cm is 60 cm
Posted on Mar 10, 2011
Need a new spark generator for a cannon SP1
What I can find is that this is no longer made.
You can try getting one of those manual flint sparkers.
May 03, 2015 | Cannon Kitchen Ranges
How to printer conect to other machin lan thorow ? pls tell me
www.networkmagic.com is a free program that you can download and allows you to see your whole network and printers and diagnose if a printer will not print or not and offers solutions.
Jul 24, 2012 | Cannon Office Equipment & Supplies
My belling 335wh oven or back hotplate doesnt work
The thermal fuse in the back of the oven is faulty. If you have a multimeter, select OHMS and check across both terminals of the fuse will show it to be open-circuit. You can compare with the grill thermal fuse. Change the oven thermal fuse and it should be ok. While you're checking this, may be you can solve my problem. both your oven elements will have one terminal connecte together by a grey wire then both earths connected by green/yellow wire, the remaining terminal hopefully has a yellow wire, can you tell me where the other end is connected to.
Jun 28, 2012 | Belling 335 Electric Kitchen Range
The left front burner will turn on for a few seconds then turn off then back on and off. It would not heat the pan on it. This is a glass top range. Are there any tests that I can do to find the problem?...
If the rest of the hotplate elements are working correctly and you are performing the same tests with all of them then you have a problem. We know that the hotplate works. When hotplates are faulty they don't turn on and off, they just don't work. This would generally be a hotplate controller problem. It sounds as if the controller is faulty and requires replacing. If you are handy you can switch the suspect hotplate controller with a good one and see what happens. This will confirm our suspicions.
Mar 04, 2011 | Kenmore 96412 / 96414 / 96419 Electric...
I LOST MY CD ON MY CANON PRIONTER AND I WANT TO INSTALL IT ON MY COMPUTER HOW COULD IT BE? PLS HELP.
go to canon website "http://www.usa.canon.com/cusa/support/consumer" and download the driver for your printer model
Aug 12, 2010 | Canon Office Equipment & Supplies
Error message on cannon super g3 copier E602-0001
Ok pls. tell exact model "superG3" is fax speed.eg. IR2200,np7161,...
Sep 23, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Have broken the glass on a new world hotplate unit. Hotplate number CKG 21822. G.C No 11.641.19. G.C No 079513 cover top assembly brown part number 931337000. Hotplate unit is ok but require a replacement...
hi...first thing to do is canvas the price of the ceramic glass top,coz the price of the glass is half or more compare to the new one..do u think if u buy a glass only it is reasonable or waste ur money?then dont try to fix it by it ur self,coz the glass u buy is no warranty for wrong instalation.call an expert technician to do it to get an assurance for the warranty for installation.
Sep 07, 2009 | Cooktops
Connect Sony Handycam to Gateway laptop
tell me the model of ur gateway laptop if u have firewire port 1394 on ur laptop u can easily connect thru cable u have to buy it separately u can go for generic one no need for an expensive branded one just check the connector type on both sides is it 4 pins or 8 pins pls let me know with details ur cam have firewire port i know but ur laptop i am not sure abt it pls tell me the model of laptop
if u dont have 1394 port on laptop then u have to buy a express card which have firewire 1394 connector or pcmcia card i dont know which card ur laptop supports after u tell me the model i can help
pls rate me for my help
Mar 06, 2009 | Sony Video Cameras
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Cannon Chesterfield C60G Kitchen Range Logo
135 people viewed this question
Top Cannon Kitchen Ranges Experts
Paul Carew
reyaazm
Level 1 Expert
Tom Chichester
Are you a Cannon Kitchen Range Expert? Answer questions, earn points and help others
