1995 mitsubishi galant es with constant check engine light,open and closed loop.How can I jump the diagnostic link? The plug is not marked for A,B terminals.Is there a way to jump the plug and count the flashes of the CEL? Please help a disabled 35 year veteran of the auto repair business! I've been fighting wiyhh SSI since 2007 and have no income! Please help me out! Thanks
  • Computers & ... Master
  • 17,433 Answers
Posted on Sep 04, 2017
SOURCE: MITSUBISHI GALANT 2002 CHECK ENGINE LIGHTS ON
dd u cjeck the ECM?
Posted on Jun 24, 2008
  • 1861 Answers
SOURCE: check engine light on 2003 tacoma
The diagnostic terminal is under the dash, on the driver side. It is white, and sort of oblong, with 2 rows of femal pins. It is NOT recommended to start probing in this connector to "get a code". You may damage the ECU by probing the pins. There is no proceedure to extract DTC by using probes. You need a scan tool.
Posted on Sep 10, 2008
  • 203 Answers
SOURCE: 95 accord v6 at check engine light
type error code 76 and make into google.joe
Posted on Nov 21, 2008
  • 1757 Answers
SOURCE: diagram for serpentine belt on a mitsubishi galant es
My sincere apologies for the severely delayed response.
I am going back to answer - unanswered questions. I have only been on this site for the past 4-months. Questions Posted have exploded (+55%) since joining.
I do not know if you still need this information, but I am answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my sincerest apologies...
Thanks.
http://www.2carpros.com/car_repair_information/year/2002/make/mitsubishi/model/galant/2002_mitsubishi_galant_drive_belt_routing_diagram.htm
Posted on Mar 04, 2010
SOURCE: 93 toyota corolla check engine light on
i have a 93 toyota camry and going down the road just giving it a little gas it will shut down. it will run great setting their but get to go no more then 20 mph driving me crazy can afford to get a pro but i need to know how to do the check engine light obd two will not do it help going crazy
Posted on Sep 04, 2010
1998 mitubishi galant es trunk wont close
The usual cause of this is the lock has closed or jammed for some reason. You should be able to re-open the lock with the key or the lever inside the car. You should be able to see the lock mechanism is open.
The mechanism hooks on to the loop on the trunk edge. This loop is adjustable, and may have worked loose.
Lastly, all the above assumes that you have not had a rear end collision or similar damage.
Dec 22, 2017 | Mitsubishi Galant Cars & Trucks
2000 Mitsubishi Galant ES has a check engine light with codes P0170 and P0303
Sometimes you can clear cars computer by taking off battery cable,maybe it will work for you, leave battery cable off about 10 mins. and try that. Just a fast thought, Hope it works for you. Billy Wyatt
Sep 07, 2013 | 2000 Mitsubishi Galant 4dr Sdn ES
02 mitsubishi galant es 2.4 Problem after engine mount replacement.
There are other possibilities too.........
Get the error code scanned,it will help.
Mar 14, 2013 | Cars & Trucks
Where are the timing marks located on a Mitsubishi 2005 Galant 2.4 engine?
They are on the crank pulley and on the camshaft drive pulleys.
Jun 05, 2012 | 2005 Mitsubishi Galant ES
I have a 2003 mitsubishi galant ES 4 cylinder and have a check engine light message on i had the code read at auto zone and they told me the third cylinder is misfiring and when it idles it jumps around...
Misfire means you need spark plugs replaced. Or spark plug coils.
That's why the whole car starts shaking because its running basically on 3 cylinders and not 4 as supposed. There is no gas compression on the 3rd cylinder because once again the spark plug is "misfiring"
There also might be even a bigger problem which could be the distributor cap where the coils are connecting outside the engine.
once you fix the problem the check engine will turn off immediately
hope that helps.
May 29, 2010 | 2003 Mitsubishi Galant
ECM switches from closed loop to open loop at idle after warmup
WHEN ENGINE GOES CLOSED LOOP TO OPEN LOOP.YOU HAVE A RICH FUEL MIXTURE.YOU HAVE A VACUUM LEAK.BY YOU HAVING ROUGH IDLING.AND A HIGH MILEAGE ENGINE I WOULD DO A COMPRESSION TEST OR CYLINDER LEAK DOWN. CHECK FOR LEAKING VALVES AND LOW COMPRESSION .THEY BOTH WILL CAUSE ENGINE TO IDLE ROUGH CAUSE MISFIRE.CAUSE OPEN LOOP CONTAMINATE HO2 SENSOR CAUSE A RICH FUEL MIXTURE.
Sep 30, 2009 | 1984 Oldsmobile Delta 88
My 2000 mitsubishi galant es went dead, motor will turn over but
do you have spark? How do you know if your timing belt is good? sometimes it doesnt break just shed the teeth which could be missing under the crankshaft. The best way to check is to have two people. have one try to start the car and see if the camshaft is actually spinning. The crankshaft will always turn but if the teeth are gone on timing belt this would cause the belt to stay in one position not moving the camshaft. so if you can remove the upper timing belt cover and do this quick inspection with someone that will tell you for sure. if it does look like it is spinning then by hand turn engine very slowly with plug coil wires removed. and make sure teeth are all there. It couldve jumped timing. (valve timing)
Feb 19, 2009 | 1997 Mitsubishi Galant
Computers & Internet Logo
Alun Cox
David Payne
David Payne
